Breathability meter verification & maintenance
发表于:2026-9-1 10:34:28|本帖共 2,413 字 4600
       Air permeability is one of the important indexes of paper quality, which directly reflects the size of the internal porosity of the paper. The tighter the paper, the smaller the air permeability index, the lower the absorption capacity. In addition, the air permeability index can also indirectly reflect the moisture resistance of the paper product. The measurement method of air permeability is to measure the amount of air passing through the paper per minute under a certain area and vacuum.
  Key points of verification
  Air permeability meter is the key equipment for measuring paper air permeability. There are several key points to pay special attention to when performing breathability measurements. The first is the tightness of the instrument to ensure that no gas leaks occur during operation. In addition, the water surface position of the U-type pressure gauge is also an important parameter for verification, and its accuracy directly affects the reliability of the measurement results.
  When calibrating the breathability meter, the pressure regulation process needs to be carried out slowly to avoid the water in the U-shaped tube entering the air box and thus interfering with the measurement. At the same time, when verifying the air tightness of the instrument, it is necessary to avoid the use of aging rubber pads to ensure stable and reliable sealing performance.
  Instrument maintenance
  In order to ensure the long-term stability and accuracy of the breathability meter, instrument maintenance is essential. In the maintenance process, we first need to pay attention to the flexibility of each valve and the firmness of each connection point to ensure that the instrument can operate normally during operation. Accessories such as pressure screws and scales also need to remain flexible to ensure that their functions are intact.
  Rubber accessories require special attention, and it must be ensured that they will not age to ensure the tightness of the breathability meter. Aging rubber material may lead to a decline in airtight performance, thus affecting the accuracy of the measurement results. Therefore, regular replacement of rubber parts is a necessary work in the maintenance of the instrument.
  Air permeability meter is an indispensable tool in paper quality control, which provides an intuitive quality assessment means for paper production. Through careful verification and maintenance, we can ensure the accuracy and reliability of the air permeability measurement, providing more accurate quality assurance for the paper manufacturing industry. The secret way inside the paper is revealed through the breathability tester, which provides scientific and reliable support for the improvement of paper quality.
