Hot products-Ball nose endmill grinder
发表于:2026-11-6 12:11:59|本帖共 525 字 2294
       According to the customer's requirment, Thor group have develop New products- Ball nose endmill grinder.Profile:Portable idiot end mill grinder, can grind 2-flute ball end mill .Grinding is accurate and rapid, easy operation with no skill to grind.With Taiwan diamond grinding wheel, only one piece can complete all procedures.It can be equipped directly with an accurate angle and long service life.Technical parameters:Mill diameter: 4-13MMPoint angle: R3-R10Motor: 220V/400WSpeed: 4000rpmDiamond wheel: CBN or SDCStandard collets: 4、5、6、7、8、9、10、11、12、13Dimension: 520×300×355mmmNet weight: 36.5kg
排版整洁,阅读起来很舒服
昨天 13:19|本帖共 12 字 回复
