谷胱甘肽S转移酶θ1(GSTθ1)单克隆抗体
发表于:2026-1-6 14:58:15|本帖共 962 字 2131
       S转移酶θ1(GSTθ1)单克隆抗体
  Monoclonal Antibody to Glutathione S Transferase Theta 1 (GSTt1)
  FOR IN VITRO AND RESEARCH USE ONLY, NOT FOR USE IN CLINICAL DIAGNOSTIC PROCEDURES!
  S转移酶θ1(GSTθ1)单克隆抗体ANTIBODY SPECIFITY
  The antibody is a mouse monoclonal antibody raised against GSTt1. It has been selected for its ability to recognize GSTt1 in immunohistochemical staining and western blotting.
  S转移酶θ1(GSTθ1)单克隆抗体APPLICATIONS
  Western blotting: 1:100-400 Immunocytochemistry in formalin fixed cells: 1:50-500 Immunohistochemistry in formalin fixed frozen section: 1:50-500 Immunohistochemistry in paraffin section: 1:10-100 Enzyme-linked Immunosorbent Assay: 1:100-200 Optimal working dilutions must be determined by end user.
  CONTENTS
  Form & Buffer: Supplied as solution form in PBS, pH7.4, containing 0.02% NaN3, 50% glycerol.
  IHC Images
  S转移酶θ1(GSTθ1)单克隆抗体
  STORAGE
  Store at 4oC for frequent use. Stored at -20oC in a manual defrost freezer for one year without detectable loss of activity. Avoid repeated freeze-thaw cycles.
支持一下
2026-6-11 09:21:03|本帖共 4 字 回复
2026-7-14 06:15:44|本帖共 4 字 回复
这个观点很有说服力。
3 天前|本帖共 10 字 回复
