The purpose and principle of transformer capacity testing
发表于:2026-10-2 14:37:38|本帖共 1,683 字 868
       1, Overview
  Transformers are an indispensable component of the power system and are widely used in transmission, distribution, and electrical installations. The capacity of a transformer is one of the important indicators to measure its performance. Therefore, testing and evaluating transformers before or regularly can ensure their safety and normal operation.
  Transformer capacity testing is an effective way to evaluate transformers, with the aim of verifying whether the actual capacity of the transformer meets design requirements and evaluating the health status of the transformer. This type of testing can be conducted through various means, including laboratory testing and on-site testing.
  2, Principle
  The principle of transformer capacity testing is mainly to measure the relationship between the output power and input power of the transformer. When the output power of a transformer exceeds its capacity limit, the transformer will experience overload, leading to burnout. Therefore, through transformer capacity testing, the actual capacity of the transformer can be determined to ensure its normal operation and avoid overload.
  The specific steps for transformer capacity testing are as follows:
  1. Determine testing methods and equipment: Determine the testing methods and equipment required to meet the testing requirements.
  2. Determine load: Determine the required load based on the actual load situation and testing requirements.
  3. Connect the testing circuit: According to the requirements of the testing method, correctly connect the transformer and load in the testing circuit.
  4. Conduct testing: Start the test and record the test data, compare the actual output power with the design capacity, and calculate the actual capacity of the transformer.
  5. Analysis results: By analyzing test data and results, evaluate the actual capacity and health status of the transformer to determine whether it is operating normally or requiring maintenance.
