Steel plate bending machine for CIP
The full name of CIP system is CIP cleaning system, economic operation cost is low, compact structure, small footprint, convenient installation and maintenance
The cleaning liquid is heated by automatic heating method, the cleaning temperature is set by the temperature controller, and the opening amount of the steam regulating valve is controlled to limit the amount of steam so that the cleaning liquid is maintained at the required temperature; the level of the liquid level in each tank of the CIP station Automatic alarm and instructions are adopted; when the concentration of the cleaning solution does not reach the cleaning concentration, the pneumatic diaphragm pump is used to add concentrated acid and concentrated alkali; during the cleaning process, the transport of the CIP solution is carried out by manual operation of the corresponding pipeline valve; inside the tank Manually replenish water when there is water shortage.
Model 2100 X 16 Hydraulic Steel plate bending machine
Capacity: 16mm mild steel
Length of Bend: 2000mm
Diameter of Bending Rolls: (2) Lower rolls, independent adjustment
Diameter of Top Roll: 260mm
Main Motor: 7.5kw
Electrics: 380V, 3-Phase, 50 Hz
Equipped With:
Independent Digital Readouts per roll
Pendent Control and Machine Console
Hydraulic End Yoke
