材质:采用无卤素硬质 PC/ABS 料制成,环保无污染,不含铅等有毒。
·防火无污染:UL94V-0,低烟微卤,遇火不燃烧,防火性及绝缘性特佳。 ·
产品构造:由槽底及槽盖组成,底槽两侧设有出线孔。 ·
工作温度:静态 -40℃持续高温至 110℃。 长时间温度高温90℃。
·使用方法:先将底槽固定,将所有要配的线装入槽内,盖上槽盖即可。 ·
产品特性: 1 . 反扣式槽盖与槽体设计组合后绝不脱落,且接合面平滑,不害伤手及擦损附近配线。 2 . 配线槽 110℃内不易断裂、变形、变色、装配省时便利。 ·更多选择:量大可按需求生产所需规格或定制长度。 3,标准长度 2 米。 Material: Made of halogen-free hard PC/ABS material, environmentally friendly and pollutionfree, lead-free and other toxic materials. · Fireproof and pollution-free: UL94V-0, lowsmoke microhalogen, non-burning in case of fire, excellent fireproof and insulation. · Product structure: It consists of the bottom of the groove and the groove cover, and there are outlet holes on both sides of the bottom groove. · Operating temperature: static -40° C continues to be high to 110° C. · Usage: Fix the bottom groove first, install all the lines to be matched into the groove, and cover the groove cover. · Product features: 1 . After the combination of the reverse buckle groove cover and the groove body design, the joint surface will never fall off, and the joint surface is smooth, which will not hurt the hands and wipe the nearby wiring. 2 . The wiring groove is not easy to break, deform, change color in 110° C, and the assembly is time-saving and convenient. · More choices: large quantities can be produced according to the required specifications or customized length
