HZS60 commercial concrete mixing plant, also known as 60 cubic meters concrete batching plant, is usually used as a small and medium-sized commercial plant, which is in great demand in the market. We all know that the theoretical productivity of the 60 concrete batching plant is 60m3 / h, then in the actual production process, how much concrete can be produced inthe concrete concrete batching plant in one hour? Customers who understand the concrete batching plant understand that the theoretical production capacity of the HZS60 concrete batching plant is 60 cubic meters per hour, but since the actual production process is affected by various factors, the actual production is often not up to the theoretical production value. If the equipment quality is reliable and the performance is superior, it is quite good to actually produce 50 cubic meters of concrete in one hour.
Zhengzhou jianxin machinery's HZS60 concrete mixing plant supports the Philippines' infrastructure. The main equipment of a set of HZS60 concrete batching plant includes: aggregate feeding system, generally adopting PLD2400 concrete batching machine; cement supply system, two 100-ton cement silos, screw conveyor, cement weighing hopper, cement weighing device; water supply system, water weighing box, supply water pump, pressurized water pump, water weighing device, water sprayer; additive supply system, additive weighing box, supply water pump, pressurized water pump, additive weighing device; batching system: motor, Reducer, JS1000 twin-shaft forced mixer; control system: air conditioning control room, industrial microcomputer, control cabinet, display instrument, switchboard, console.
Zhengzhou jianxin machinery's HZS60 concrete batching plant supports the Philippines' infrastructure. When considering investing in the construction of HZS60 concrete batching plant, we must first consider the planning and design of the site (which can be combined with the configuration and floor space of the HZS60 batching plant); the design of the plant plan; the demand for concrete Determine (construction project concrete daily demand and duration of construction period); mixing plant staffing and training; mixing plant equipment and related ancillary products to purchase. Do you know what you are doing, and you will not blindly choose. Zhengzhou Jianxin Machinery HZS60 Concrete Mixing plant has reliable performance, high efficiency and strong continuous working ability. It is suitable for engineering construction with large concrete demand and small and medium-sized commercial plant enterprises. |
