Technical Characteristics Of The Wrapping Machine
发表于:2026-8-19 10:26:38|本帖共 895 字 842
       The pallet wrapping machine widely uses the assembly cost of foreign trade export, food and beverage, plastic chemical and other products to improve production efficiency, and can prevent damage of the goods during the handling process, and play the role of dustproof, moisture proof and cleaning. Let us understand the technical characteristics of the pallet wrapping machine!
  The pallet wrapping machine technical features:
  1. The professional wrapping machine adopts photoelectric automatic detection height.
  2. Tension elastic adjustment, the maximum stretch ratio of 1:3.
  3. The number of laps at the top and bottom can be set arbitrarily.
  4. Accurate zero return status.
  The main features of the wrapping machine structure:
  1. The pallet wrapping equipment has a stable production structure.
  2. Digital electronic control loop with high stability, long life and low failure rate.
  3. Slowly start and stop the device to prevent the upper packaging from falling.
  4. Touch screen, easy to operate.
  5. The upper and lower packaging can input data settings.
