粘度杯转换 下表列出的是各主要型号的粘度杯换算表,从流出的时间(秒)换算成粘度单位厘沲(cst)。 这是由不同的国际标准计算器贡献而成的。 每一种粘度杯的设计都有其独特性,因此在比较不同杯种的粘度值的时候要特被小心。 这些值都是绝度值,不包括允许偏差,因为根据标准不同,这些值差别很大。 <td class="et2" height="25" width="78" style="border-bottom: #000000 0.5pt solid; border-left: #000000 0.5pt solid; font-style: normal; width: 58.5pt; background: #e3e3e3; height: 18.75pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 129pt; background: #e3e3e3; height: 18.75pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 96pt; background: #e3e3e3; height: 18.75pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 18.75pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 18.75pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 18.75pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 18.75pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 18.75pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; border-left: #000000 0.5pt solid; font-style: normal; width: 58.5pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 40.5pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; text-align: center; border-left: #000000 0.5pt solid; font-style: normal; width: 48pt; background: #e3e3e3; height: 19.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; border-top: #000000 0.5pt solid; font-weight: 400; border-right: #000000 0.5pt solid; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 58.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 40.5pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; font-style: normal; width: 48pt; height: 14.25pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 400; text-decoration: none; width: 541.5pt; height: 25.5pt; color: #000000; font-size: 10pt; vertical-align: bottom; font-weight: 700; text-decoration: none; C.<span style=" |
