螺杆泵有哪些优点? What are the advantages of screw? 1)压力和流量范围宽阔。压力约在3.4-340千克力/cm 2,流量可达18600cm3/分; 1) The wide range of pressure and flow. Pressure of about 3.4-340 kgf / cm 2, flow rate of up to 18600cm3 / min; 2)运送液体的种类和粘度范围宽广; 2) The delivery of the liquid type and a wide viscosity range; 3)因为泵内的回转部件惯性力较低,故可使用很高的转速; 3) Because of the rotary pump parts, lower inertia, it can use a high speed; 4)吸入性能好,具有自吸能力; 4) Inhalation of good performance, with self-absorption capability; 5)流量均匀连续,振动小,噪音低; 5) The flow uniformly continuous, little vibration, low noise; 6)与其它回转泵相比,对进入的气体和污物不太敏感; 6) when compared with other rotary pumps, gas and dirt entering the less sensitive; 7)结构坚实,安装保养容易。7) The structure of a solid, installation and maintenance easy. |
