在线PH电极选择指南
发表于:2026-6-14 12:40:34|本帖共 1,358 字 3940
       应用普通电极平头自清洗标准应用S200C, S222CD S260CD,S261CD所有型号Flat-surface,self-cleaningS8000系列泥浆Not available. See nextcolumn.所有型号Flat-surface,self-cleaningS8000系列粘性物料Not available. See nextcolumn.所有型号Flat-surface,self-cleaningS8000系列低离子状态low ionic version of S200CD-LC S650CD-LC forsubmersion pH (CPVC)(浸没式安装) S660CD-LC for in-linePH (CPVC) (管道式安装) S655CD-LC forinsertion/wet tap pH (CPVC)(插入式安装)温度高于 160° F(71摄氏度)高温版本S200CD-HT S8000系列S650CD-HT for submersion pH (CPVC)(浸没式安装) S660CD-HT for in-line PH (CPVC) (管道式安装) S655CD-HT forinsertion/wet tap pH (CPVC)(插入式安装)适用于环境Not available. See nextcolumnAdd HF to end of part number example: Submersion model S650CD becomes S650CDHF无法接地的环境Not available. See nextcolumnS8000See Ground Loop InterruptElectrodesEtchants (nickelSulfamate,..)蚀刻剂Not available. See nextcolumn S645CD-SI for by-pass ORP (CPVC) S645KD-SI for by-pass ORP (PVDF) 混合水和溶剂Not available. See nextcolumnS8000系列KYNAR versions of electrodes –SeeFlat Surface, Self-Cleaning pH and ORPElectrodes水平安装或从下往上安装Not available. See nextcolumnStandard for insertion model(S655CD,S655KD) 重金属,硫化物,,蛋白质样品(Cd,Zn,…)S200C, S222CD S260CD,S261CDS8000系列All models See Flat-surface,self-cleaning水、油混合Not available. See nextcolumnS645CD and FC60C (acceleratessample past sensor faster to prevent oil build-up andfouling)液体包含溶解气体Not available. See nextcolumn看水平安装或从下往上安装部分高PH样品(up to pH14)S200C,… all modelsS8000系列All Models See Flat-surface, self-cleaning低 pH S200C,…..S8000系列All models See Flat-surface,self-cleaning
2026-8-2 22:54:33|本帖共 4 字 回复
