超微粉化是药品可以提高产品药效的基础。超微粉碎机物料通过投料口进入柱形粉碎室,被沿着研磨轨做圆周运动的研磨轮碾压、剪切而实现粉碎。气流粉碎机被粉碎的物料通过风机引起的负压气流带出粉碎室,进入物料收集系统,经过滤袋过滤,空气被排出,物料、粉尘被收集,完成粉碎。气流粉碎机主要适用于的粉碎机理决定了其适用范围广、成品细度高等特点,典型的物料有:超硬的金刚石、碳化硅、金属粉末等,高纯要求的:陶瓷色料、医药、生化等,低温要求的:医药、PVC。通过将气源部份的普通空气变更为氮气、二氧化碳气等惰性气体,可使本机成为惰性气体保护设备,适用于易燃易爆、易氧化等物料的粉碎分级加工。西药微粉化可提高以及药效,降低用药量,早已没有得到发展证明,并广泛用不动声色西药制药中。中药也不例外,绝大部分多数研究中药是天然的动、植物,药效成分分析通常主要分布于细胞内与细胞间质且以细胞内为主,超细粉碎后,细胞壁被破碎,细胞内有效成分能够得以实现充分利用暴露自己出来,这样的药物已经进入我们体内后,有效管理成分的释放中国速度及释放量会大幅度不断提高,用药量随之出现大幅度减少,而疗效却不会降低,反能提高。在传统中医中药炮制中,对一些国家珍贵药材或不适宜用煎煮方式方法的药材,也采用研细磨粉冲服的方法,以达到企业减少材料用量,提高临床疗效的目的。 Ultramicro powder is the basis for improving medical drugs. Western medicine powder can improve the effect and reduce the dosage, which has been proved and widely used in western medicine. Chinese medicine is no exception, the vast majority of Chinese medicine is natural animals and plants, medicinal ingredients are usually distributed in the intracellular and intercellular substances, mainly intracellular, ultrafine comminuted, cell wall is broken, the effective components in the cell can be fully exposed, such drugs into the body, the release rate and release rate of active components will be greatly increased, dose will be greatly reduced, but its efficacy has not been reduced to improve. In the processing of traditional Chinese medicine, some precious medicinal materials or methods that are not suitable for decoction of medicinal materials are also used to grind and blunt, so as to reduce the dosage and improve the curative effect. 据有关问题研究分析报告数据显示,采用一些常规管理方式进行粉碎的中药末,其单个粒子常由数个或数十个细胞所组成,细胞的破壁率极低。因药物通过粒子系统内部的朋效分将穿过几个或数十个细胞壁及细胞膜方可释放发展出来,释出中国速度很慢,又因药物在体内停留的时间非常有限,在低速释放的情况下释出率也不会高;药物使用粒子粗,吸附在肠壁上的可能性也会减少,其中很大一部分作为药物以及粒子的成分在未没有释放自己出来工作之前就被排出体外,使药物的利用度进一步有效降低。 According to the relevant research report, the traditional Chinese medicine end is crushed in a conventional way.
