仪器中文名称 仪器英文名称 英文缩写 探针台 Probe station 原子发射光谱仪 Atomic Emission Spectrometer AES 电感偶合等离子体发射光谱仪 Inductive Coupled Plasma Emission Spectrometer ICP 直流等离子体发射光谱仪 Direct Current Plasma Emission Spectrometer DCP 紫外-可见光分光光度计 UV-Visible Spectrophotometer UV-Vis 微波等离子体光谱仪 Microwave Inductive Plasma Emission Spectrometer MIP 原子吸收光谱仪 Atomic Absorption Spectroscopy AAS 原子荧光光谱仪 Atomic Fluorescence Spectroscopy AFS 傅里叶变换红外光谱仪 FT-IR Spectrometer FTIR 傅里叶变换拉曼光谱仪 FT-Raman Spectrometer FTIR-Raman 气相色谱仪 Gas Chromatograph GC 高压/效液相色谱仪 High Pressure/Performance Liquid Chromatography HPLC 离子色谱仪 Ion Chromatograph 凝胶渗透色谱仪 Gel Permeation Chromatograph GPC 体积排阻色谱 Size Exclusion Chromatograph SEC X射线荧光光谱仪 X-Ray Fluorescence Spectrometer XRF X射线衍射仪 X-Ray Diffractomer XRD 同位素X荧光光谱仪 Isotope X-Ray Fluorescence Spectrometer 电子能谱仪 Electron Energy Disperse Spectroscopy 能谱仪 Energy Disperse Spectroscopy EDS 质谱仪 Mass Spectrometer MS ICP-质谱联用仪 ICP-MS ICP-MS 气相色谱-质谱联用仪 GC-MS GC-MS 液相色谱-质谱联用仪 LC-MS LC-MS 核磁共振波谱仪 Nuclear Magnetic Resonance Spectrometer NMR 电子顺磁共振波谱仪 Electron Paramagnetic Resonance Spectrometer ESR 极谱仪 Polarograph 伏安仪 Voltammerter 自动滴定仪 Automatic Titrator 电导仪 Conductivity Meter pH计 pH Meter 水质分析仪 Water Test Kits 电泳仪 Electrophoresis System 表面科学 Surface Science 电子显微镜 Electro Microscopy 光学显微镜 Optical Microscopy 金相显微镜 Metallurgical Microscopy 扫描探针显微镜 Scanning Probe Microscopy 表面分析仪 Surface Analyzer 无损检测仪 Instrument for Nondestructive Testing 物性分析 Physical Property Analysis 热分析仪 Thermal Analyzer 粘度计 Viscometer 流变仪 Rheometer 粒度分析仪 Particle Size Analyzer 热物理性能测定仪 Thermal Physical Property Tester 电性能测定仪 Electrical Property Tester 光学性能测定仪 Optical Property Tester 机械性能测定仪 Mechanical Property Tester 燃烧性能测定仪 Combustion Property Tester 老化性能测定仪 Aging Property Tester 生物技术分析 Biochemical analysis PCR仪 Instrument for Polymerase Chain Reaction PCR DNA及蛋白质的测序和合成仪 Sequencers and Synthesizers for DNA and Protein 传感器 Sensors 其他 Other/Miscellaneous 流动分析与过程分析 Flow Analytical and Process Analytical Chemistry 气体分析 Gas Analysis 基本物理量测定 Basic Physics 样品处理 Sample Handling 金属/材料元素分析仪 Metal/material elemental analysis 环境成分分析仪 CHN Analysis 发酵罐 Fermenter 生物反应器 Bio-reactor 摇床 Shaker 离心机 Centrifuge 超声破碎仪 Ultrasonic Cell Disruptor 超低温冰箱 Ultra-low Temperature Freezer 恒温循环泵 Constant Temperature Circulator 超滤器 Ultrahigh Purity Filter 冻干机 Freeze Drying Equipment 部分收集器 Fraction Collector 氨基酸测序仪 Protein Sequencer 氨基酸组成分析仪 Amino Acid Analyzer 多肽合成仪 Peptide synthesizer DNA测序仪 DNA Sequencers DNA合成仪 DNA synthesizer 紫外观察灯 Ultraviolet Lamp 分子杂交仪 Hybridization Oven PCR仪 PCR Amplifier 化学发光仪 Chemiluminescence Apparatus 紫外检测仪 Ultraviolet Detector 电泳 Electrophoresis 酶标仪 Microplate Reader 或(ELIASA) CO2培养箱 CO2 Incubators 倒置显微镜 Inverted Microscope 超净工作台 Bechtop 流式细胞仪 Flow Cytometer 微生物自动分析系统 Automatic Analyzer for Microbes 生化分析仪 Biochemical Analyzer Blood-gas Analyzer Electrolytic Analyzer Urine Analyzer 临床药物浓度仪 Analyzer for Clinic Medicine Concentration Hematocyte Counter 菌落计数仪 Colony counters 恒温·干燥器/恒温恒湿器 Drying Ovens/Humidity Chambers 送风定温恒温器 Forced Convection Constant Temperature Ovens 惰性气体恒温器 Inert Gas Ovens 精密恒温器 Precision Constant Temperature Ovens 洁净恒温器 Clean Ovens 送风定温干燥器 Forced Convection Constant Temperature Drying Ovens 空气幕送风定温恒温器 Forced Convection Ovens With Air Curtain 定温干燥箱 Constant Temperature Drying Ovens 角形真空定温干燥器 Vacuum Drying Ovens 恒温恒湿器 Constant Temperature and Humidity Chambers 流水线设备 In-Line System for Underfill Adhesive and Encapsulation 恒温培养器 Constant Temperature Incubators--- 可程式低温培养器 Low Temperature Program Type Incubators 低温培养器 Low Temperature Incubators 低温稳定性培养器 Low Temperature Stability Incubators 培养器 Incubators CO2培养器 CO2 Incubators 振荡培养器 Shaking Incubators 冻结干燥器 Freeze Dryers--- 冻结干燥器 Freeze Dryers 离心形冻结干燥器 Centrifugal Freeze Dryers 灭菌器 Sterilizers--- 干热灭菌器 Drying Sterilizers 高压灭菌器 Autoclaves Sterilizers Low Temperature Plasma Sterilizers 环形燃烧管灭菌器 Loop Cinerator 纯水制造装置 Water Purifiers--- 纯水制造装置 Water Stills 超纯水制造装置 Ultra-pure Water Purifiers 简易纯水制造装置 Water Purifiers 超纯水制造装置系统 Ultra-pure Water Purifier System 大容量纯水制造装置 Water Purifiers System 洗净器 Washers--- 实验室玻璃器皿清洗机 Laboratory Glassware Washers 超声波清洗机 Ultrasonic Cleaners 大型超声波清洗机 Aqueous Ultrasonic Cleaning Systems 超声波试管清洗机 Ultrasonic Pipet Washers 超声波清洗机 Ultrasonic Cleaners 恒温液槽 Constant Temperature Baths--- 投入式恒温装置 Constant Temperature Devices 油槽 Oil Baths 振荡式低温水槽 Low Constant Temperature Shaking Baths 深槽形恒温水槽 Constant Temperature Water Baths 粘度测定槽 Kinematic Viscosity Baths 液压式恒温水槽 Constant Temperature Water Baths 精密低温恒温水槽 Precision Low Constant Temperature Water Baths 低温恒温水槽 Low Constant Temperature Water Baths 试验管加热板 Heating Blocks 冷却液体循环器 Cooling Liquid Circulators 冷却水循环器 Cooling Water Circulators 便携式冷却器 Immersion Cooler 寒流捕获器 Cooling Trap 冷却水外部循环器 Cooling Water Circulators 试验槽 Thoughs 高温炉 High Temperature Furnaces Heating Apparatus--- 马弗炉 Muffle Furnaces 超高温电气炉 Ultra-High Temperature Electric Furnaces 高温电气炉 High Temperature Electric Furnaces 真空气体置换炉 Gas Replacement Vacuum Furnaces 造粒干燥装置 Granulating and Drying Apparatus for Wet Powder Body and Liquid--- 喷雾干燥器 Spray Dryer 有机溶剂喷雾干燥器 Spray Dryer 生产线喷雾干燥器 Spray Dryer for Product Line 浓缩器 Evaporators--- 旋转蒸发仪 Rotary Evaporators 溶媒回收装置 Solvent Recovery Unit 乳化·搅拌·振荡器 Homogenizers, Stirrers, Shakers--- 磁力搅拌器 Magnetic Stirrers 加热板 Hot Plates 振荡器 Shakers 送液·减压·加压装置 Aspirators, Pumps, Compressors 搅拌器 Stirrers 实验室自动乳钵 Laboratory Mill/Universal Ball Mill 粉碎器 Cutting Mills 生命科学关连仪器 Life-Science Related Instruments 生物技术关连仪器·食品分析仪器 Bio-Technology Related Instruments, Food Analysises Instruments— 形态观察分析系统 Mapping Analyzer 生物分子间相互作用分析系统 Biomioleculer Interaction Analysis System 高速液相色谱仪 LC-CE/CEC System 血管壁细胞混合培养系统 Dynamic Coculture System 动植物破碎机 基因检查仪器 Genopattern Analyzer ATP测定器 ATP Measuring Instrument
上海虔钧科学仪器有限公司 Shanghai Qian Jun Scientific Instruments Co.,Ltd 地址:上海市奉贤区海湾镇五四公路4399号38幢1453室 |
