电子鼻运用SSNN算法进行化学品分类识别研究
发表于:2026-5-13 08:42:36 3109
       Sampling Spiking Neural Network Electronic Nose on a Tiny-Chip
  Hoda S. Abdel-Aty-Zohdy Microelectronics & Bio-Inspired Systemd Design Department of electrical and Computer Engineering Oakland University, Rochester, MI, USA
  Jacob N. Allen Microelectronics & Bio-Inspired Systemd Design Department of electrical and Computer Engineering Oakland University , Rochester, MI, USA
  Abstract
  Chemicals classification using a new Sampling Spiking Neural Network (SSNN) approach is presented in this paper with experimental measurements using the Cyranose 320 sensor array. The network is unique in its minimal yet powerful design which implements on chip learning and parallel monitoring to detect binary odor patterns with high noise environment. The SSNN architecture is further implemented on a 0.5 um CMOS technology tiny-chip designed to work in conjunction with a 256K external SRAM memory. It handles the routing of spike signal among 32,000 synapses and 255 neurons. At the same time, it tracks and records learning statistics. The chip can be used in parallel with other SSNN co processors for very large systems. Experimental measurements of our SSNN E-Nose classifier, compared to other E-nose systems proved superior in capability, size, and correctness.
  本文提出了一种新的神经网络(SSNN)方法对化学品进行分类识别,并利用Cyranose 320电子鼻进行了实验测量。该网络的独特之处在于其最小但功能的设计,实现了片上学习和并行监控以检测高噪声环境下的二元气味模式。SSNN架构进一步实现在0.5umCMOS技术的微型芯片上,该芯片设计为与256K外部SRAM存储器协同工作。它处理32000个突触和255个神经元之间的尖峰信号路由。同时,对学习统计数据进行跟踪记录。对于非常大的系统,该芯片可以与其他SSNN协处理器并行使用。与其他电子鼻系统相比,我们的SSNN电子鼻分类器的实验测量结果在性能、尺寸和正确性方面都表现出了性。
支持
2026-5-23 14:02:59 回复
2026-5-29 09:32:42 回复
提示: 作者被禁止或删除 内容自动屏蔽
