Socks, as an indispensable part of our daily life, not only provide us with warmth and comfort, but also greatly affect our wearing experience. Especially in sports or slippery environments, the anti slip performance of socks is particularly important. In order to meet this demand, anti slip adhesive technology has emerged and become an indispensable part of modern sock production.
The anti slip dispensing process, as the name suggests, is to apply a layer of anti slip adhesive to the bottom or key areas of socks. This rubber material usually has excellent slip resistance and wear resistance, which can effectively increase the friction between socks and the ground, preventing slipping.
In the production process, the first step is to determine the areas that need to be glued based on the design and purpose of the socks. Generally speaking, the forefoot, heel, and sides of socks are areas with high anti slip performance requirements, so these areas are the focus of the dispensing process. Next, use professional dispensing equipment to evenly apply the anti slip rubber liquid to the selected area. During this process, it is necessary to strictly control the amount of adhesive and the coating thickness to ensure the anti slip effect while not affecting the comfort and breathability of the socks.
After completing the adhesive coating, the socks need to go through a period of drying and curing. During this process, the glue will gradually combine with the sock material to form a strong anti slip layer. Finally, after strict quality inspection and packaging, a pair of socks with excellent anti slip performance was produced.
The application of anti slip glue technology not only improves the anti slip performance of socks, but also enhances their durability to a certain extent. Due to the wear resistance of the adhesive layer, it can effectively extend the service life of socks. In addition, the anti slip dispensing process can also be customized according to different needs, such as adjusting the formula of the adhesive, changing the coating method, etc., to meet the needs of different occasions and people.
In short, the anti slip glue process is an important technology in modern sock production. It can not only improve the anti slip performance of socks, but also enhance their durability. Nowadays, this technology is widely used in most high-performance sports equipment, such as outdoor and indoor sports such as football, basketball, yoga, dance, etc. With the advancement of technology and the constant changes in consumer demand, the anti slip dispensing process will also continue to develop and improve, bringing us a more comfortable and safe wearing experience.
