Button Head Hex Socket Screws: Full Thread, Partial Thread and Metric Options
发表于:2026-10-19 12:01:27|本帖共 2,946 字 2601
       Button head hex socket screws are widely used in machinery, equipment, and industrial assemblies due to their low-profile head design and reliable fastening performance. Different thread designs are available to meet various application requirements.
  As a professional hex socket screws manufacturer, Xinchi Fastener Factory is very pleased to introduce the differences between full thread, partial thread, metric, and inch thread options, hoping it could help customers select the right button head hex socket screws for their projects.
  The thread design of a button head hex socket screw affects its installation method, clamping performance, and suitability for different applications. Depending on the assembly requirements, customers can choose from full thread, partial thread, metric thread, or inch thread types.
  Selecting the correct thread option ensures better compatibility and more reliable fastening performance.
  Full thread button head hex socket screws have threads running along the entire length of the screw shaft. This design provides maximum thread engagement when installed into a threaded hole or nut.
  Full thread button head socket screws are commonly used in:
  They are suitable for applications where the screw needs consistent thread engagement and secure fastening.
  Partial thread button head hex socket screws feature a smooth shank section below the screw head, with threads only on part of the screw length. This structure can improve alignment and provide stronger clamping when fastening thicker components.
  Compared with full thread screws, partial thread button head socket screws are often selected for applications where higher shear strength and better load distribution are required.
  Button head hex socket screws are available in both metric and inch thread standards to meet different market requirements.
  Metric button head socket screws, such as M3, M4, M5, M6, and M8 sizes, are widely used in international machinery and industrial products.
  Inch thread button head hex socket screws, including UNC and UNF thread types, are commonly used in equipment designed according to imperial standards, especially in North American markets.
  Choosing the correct thread standard helps ensure proper fitting and smooth assembly.
  Choosing the right button head hex socket screws depends on the application, assembly structure, and working conditions.
  Before ordering, customers should consider:
  The correct screw specification can improve fastening reliability and reduce installation problems.
  Xinchi Fastener Factory has been specializing in fastener manufacturing since 2007, providing reliable fastening solutions for customers worldwide.
  With 102 cold heading machines, Xinchi has strong production capacity with a daily output of more than 10 million pieces. The completed new factory covers 30,000 square meters, including two six-story buildings, providing stable production capacity and efficient manufacturing conditions.
  With professional cold heading technology, strict quality control, and years of experience in fastener production, Xinchi Fastener Factory supplies high-quality button head hex socket screws and other customized fasteners, including nuts, screws, bolts, rivets, and washers for industrial, machinery, and assembly applications.
