In the current global architectural decoration industry, the demand for ceiling materials is gradually shifting from single decorative effect to multi-dimensional integration of safety, environmental protection, ventilation, durability and design sense. Traditional gypsum ceilings, aluminum gusset plates and solid metal ceilings have obvious shortcomings in complex application scenarios: poor air permeability, difficult later maintenance, insufficient fire performance, single style and short service life. After years of market research, technical research and development and repeated testing, DONGJIE has launched this expanded metal mesh ceiling, aiming to solve the pain points of the industry and meet the diversified, personalized and high-standard needs of modern architectural decoration projects.
Our expanded metal mesh ceilings are manufactured with strictly selected high-grade metal raw materials, including high-strength Q235 low-carbon steel, corrosion-resistant 304/316 stainless steel, lightweight and high-hardness aluminum alloy and other optional materials, all of which meet international environmental protection and quality certification standards. Adopting advanced precision automatic expanding and stretching production technology, the whole metal sheet is cut and stretched integrally without welding, forming a uniform and stable diamond, hexagonal or custom-shaped mesh structure, which not only ensures the integrity of the product, but also greatly enhances the structural strength and load-bearing capacity of the ceiling panel. Compared with traditional assembled ceiling products, our one-piece forming process eliminates the hidden danger of panel deformation and falling off, and the service life is as long as 15-20 years, greatly reducing the cost of later replacement and maintenance.
This series of expanded metal mesh ceilings has a wealth of core competitive advantages, fully meeting the strict requirements of global high-end construction projects:
First of all, superior physical and chemical properties: the product reaches A-class non-combustible fire rating, complying with international building fire safety standards, and can be safely used in high-density public places; it has excellent corrosion resistance, rust resistance and moisture resistance, whether in coastal areas with high salt and humidity, underground spaces or industrial environments with certain corrosive gases, it can maintain stable performance without rusting and fading; the surface adopts hot-dip galvanizing, electrostatic powder coating, fluorocarbon spraying (PVDF) and other advanced treatment processes, with strong weather resistance, not easy to yellow and crack under long-term light exposure. Secondly, excellent functional practicality: the hollow mesh design has a ventilation rate of up to 30%-70%, which can effectively promote indoor air circulation, cooperate with the HVAC system to improve energy efficiency, and reduce the operation cost of air conditioning and ventilation; the open structure is convenient for the installation, inspection and maintenance of indoor top pipelines, wires, lamps and fire-fighting facilities, solving the problem of difficult later maintenance of traditional closed ceilings; the product is lightweight, the weight per square meter is only 1.2-3.5kg, which effectively reduces the load bearing of building structures, and is more convenient for transportation and installation, saving construction time and labor costs. Thirdly, outstanding architectural decorative value: the product presents a unique industrial style, modern minimalist aesthetic effect, mesh size, aperture, panel size, color can be customized at will, can create a layered, transparent visual space effect. Whether it is a high-end commercial space pursuing fashion sense, a public building focusing on practicality, or an industrial space requiring functional priority, it can be perfectly integrated, breaking the monotony of traditional ceilings and becoming a bright spot in architectural space design. Fourthly, green and environmental protection: all raw materials are 99% recyclable metal materials, no formaldehyde, no harmful volatile substances, in line with the global green building, low-carbon environmental protection development trend, can help construction projects obtain international green building certification.
Our expanded metal mesh ceilings have an extremely wide range of applications, covering almost all types of architectural decoration scenarios: in commercial spaces, it is widely used in shopping malls, hotel lobbies, office buildings, coffee shops, exhibition halls, etc., creating a fashionable and transparent space atmosphere; in public infrastructure, it is the first choice for airports, high-speed rail stations, subway stations, stadiums, hospitals, libraries, schools and other places, with safety, durability and easy maintenance as core advantages; in industrial and logistics spaces, it is suitable for factories, warehouses, logistics centers, workshop ceilings, with ventilation, fire prevention and corrosion resistance to meet industrial use needs; in special architectural design, it can also be used as suspended ceiling, curved ceiling, wall decorative mesh, partition mesh, etc., to meet the personalized design needs of architects.
In terms of customization services,DONGJIE provides a full-process personalized customization solution for global customers. We can customize exclusive ceiling products according to the customer's project design drawings, including material selection, mesh shape and aperture, panel thickness (0.5mm-4.0mm), specification size (conventional 600×600mm, 600×1200mm, can be customized to large size panels), surface color and treatment process, installation accessories matching, etc. The company has a professional R&D and design team, which can provide free technical consultation, CAD drawing optimization, sample production and other pre-sales services to ensure that the product is perfectly matched with the project needs.
In order to ensure the efficient and stable supply of global orders, DONGJIE has a large-scale modern production base, equipped with fully automatic production lines, strict quality inspection system, from raw material incoming inspection to finished product factory testing, each link is strictly controlled to ensure that each product meets international quality standards. At the same time, we have a mature international logistics and supply chain system, which can achieve fast production scheduling, on-time delivery and safe transportation for global orders, covering Europe, Southeast Asia, the Middle East, Africa, North America, South America and other more than 60 countries and regions.
Global customers can log in to DONGJIE's official independent website to browse complete product parameters, high-definition real-scene case pictures, detailed technical manuals and installation guidelines; online one-click inquiry, sample application, quotation consultation and other services, professional foreign trade sales team and technical team 24 hours online to answer questions, provide one-stop procurement and technical support services.
