We got an order from American client for the vacuum lifter machine to lift and move the big plastic plate in their workshop. Our vacuum lifter can handle and process many different material plates, like the glass, steel, wood, marble, aluminum etc. Here is the photo for your review. If you like it, please tell us the information of plate size and weight, as well as the plate material, whether the surface is smooth or rough, then we will design the best hydraulic electric vacuum lifter machine for you.
