通过LC-ICP-MS方法进行铬的价数分析
发表于:2026-3-6 13:29:03|本帖共 707 字 4230
       使用RSpak NN column*1的填料填充在PEEK柱管中,可以用来进行三价铬和六价铬的分析。NN系列的填料是键合了磺基的聚羟基甲基丙烯酸酯。主要是通过尺寸排阻模式进行分离。但由于键合了磺基,所以也有离子排阻的作用。 Sample : 5μg/L each, 25μL 1. Cr(III), Cr(NO3)3 2. Cr(VI), K2CrO4 Sample was first prepared by using 10mM nitric acid to make a 1 mg/L solution; and then it was diluted with phase to the final concentration of 5μg/L.
  Column : Shodex *1NN-414 4D(4.6mmID*150mm) PEEK housing type can be prepared as a customized orderEluent : 90mM (NH4)2SO4 + 10mM NH4NO3(pH3.0 adjusted by HNO3)Flow rate : 0.3mL/minDetector : ICP/MS, Cr at m/z=52Column temp. : 40℃Reference: Harald Hagendorfer, Walter Goessler. Separation of chromium(III) and chromium(VI) by ion chromatography and an inductively coupled plasma mass spectrometer as element-selective detector. Talanta. 2008, vol.76, p.656-661.
2026-5-20 04:58:42|本帖共 4 字 回复
感谢分享宝贵经验
2026-6-8 17:52:14|本帖共 8 字 回复
提示: 作者被禁止或删除 内容自动屏蔽
