膏药机 产品简介
发表于:2026-1-13 11:55:20|本帖共 1,601 字 3005
       膏药机 产品简介
  下面是小型膏药机的具体介绍: 膏药作为中华传统中药剂型历史悠久,但长期以来,生产工艺大多延用加温溶化、手工摊制的制作方式。由于它具有粘稠的特性,不仅生产效率低,而且手工操作,使剂量难以达到药典所规定的要求,与目前制药工业的发展不相适应。
  Following is a detailed introduction of the small plaster machine: plaster has a long history as a traditional Chinese medicine dosage form, but for a long time, the production process mostly uses heating melting, manual spreading method. Because of its viscous properties, not only the production efficiency is low, but also the manual operation makes the dosage difficult to meet the requirements prescribed by the Pharmacopoeia, which is not compatible with the current development of the pharmaceutical industry.
  为此,研制了一种自动膏药机,采用了恒温、恒压,流量由时间控制的方法,有效地解决了膏药制作中难掌握的定量滩涂和自动成型的问题,并且对生产不同形状的膏药具有一定的通用性。
  For this reason, an automatic plaster machine is developed, which adopts the method of constant temperature, constant pressure and time control of flow rate. It effectively solves the most difficult problems in plaster production, such as quantitative beach and automatic moulding, and has certain universality in the production of plaster of different shapes.
  小型膏药机主要适用于中医诊所和膏药加工量不大的生产者。机器的特点是灵活性大,可根据不同的客户需求制成不同大小和形状的膏药,重量可任意设定。操作方法是把需要膏药的克重输入后,把膏药布放在称重平台上,机器就根据设定的重量自动出药,到克重自动关闭,关闭后将膏药在成型机下成型即可。
  The plaster machine is mainly suitable for Chinese medicine clinics and producers with a small amount of plaster processing. The machine is characterized by flexibility, can be made according to different customer needs of different sizes and shapes of plaster, weight can be arbitrarily set. The operation method is to input the weight of the plaster, put the plaster cloth on the weighing platform, and the machine automatically dispenses the plaster according to the set weight, and automatically shuts down the weight of the plaster. After closing, the plaster can be formed under the forming machine.
2026-3-17 21:38:40|本帖共 4 字 回复
2026-6-24 01:17:01|本帖共 4 字 回复
