一种用于中枢神经损伤、再生和运输的微流体仪
发表于:2026-6-3 15:03:37|本帖共 903 字 3892
       The neuron device offered by Xona Microfluidics, LLC is fabricated out of optically transparent and biologically inert Polydimethylsiloxane (PDMS). The neuron device consists of two chambers connected by microgrooves.
  The neuron device makes it possible for the researcher to fluidically isolate cell bodies from axons. The device consists of two chambers connected by a much smaller microgroove barrier. The hydrostatic pressure between the two chambers separated by the microgrooves allows the researcher to fluidically isolate each chamber. This is accomplished by keeping the volumes in the wells on one side of the device higher than the other side of the device. The difference in volume creates hydrostatic pressure, thus fluidically isolating each compartment.
  The total volume of the device is about 600 ul allowing the researcher to use less of the expensive reagents typically used in neuronal culture.
  The neuron device also makes it possible to perform axotomy (cutting axons via vacuum aspiration in the distal chamber) and observing their regrowth.
不知道这套系统在高温高湿环境下表现如何?
3 小时前|本帖共 20 字 回复
