离心泵自动供水装置的技术要求
发表于:2026-4-4 10:20:26 1639
       离心泵自动供水装置的技术要求 离心泵自动供水装置的技术要求 Centrifugal automatic water supply devices, the technical requirements (1)井管的底阀安装在地面上。 1) well pipe at the end of valve installed on the ground. (2)压力罐出水管高程-水泵出水管高程≥0.5米。 (2) Pressure tank outlet pipe elevation - water pump outlet pipe elevation ≥ 0.5 Mi. (3)在次供水前压力罐内水位高于水泵出水管水位。 (3) At the first pre-pressure water pump outlet pipe above the water level in the tank water level.
2026-4-9 00:47:46 回复
2026-5-26 22:59:06 回复
