Dual-spindle machining center: Reinventing efficiency in precision manufacturing
发表于:3 天前|本帖共 1,794 字 1933
       Dual-spindle machining center represents the latest development direction of CNC machine tool technology. Its core value lies in the geometric improvement of machining efficiency through the collaborative work of dual spindles. Compared with traditional single-spindle equipment, it has three major advantages:
  Efficiency doubled: dual spindles can simultaneously process two identical workpieces, or divide the work to complete different processes of a workpiece, and the theoretical production capacity is increased by 70-99%
  Precision guarantee: multi-faceted processing is completed through one clamping, and the cumulative error is reduced by more than 60%
  Space optimization: the floor area is only 30% larger than that of the single-spindle model, but the output is doubled
  Spindle system
  Independent drive design: each spindle is equipped with a separate servo motor (common power 7.5-15kW)
  Speed matching: dual spindle synchronization accuracy reaches ±0.001rpm (using high-resolution encoder)
  Temperature control: the oil cooling system maintains a temperature difference of
  Motion system
  Components
  Technical standards
  Performance indicators
  Guide rails
  45mm roller linear guides
  Load capacity 50kN
  Screws
  C3 grade 4010 ground screws
  Positioning accuracy ±0.003mm
  Bearings
  P4 grade angular contact bearings
  Axial runout
  Intelligent control system
  Dual-channel CNC: each spindle can be independently programmed
  Collision warning: 3D simulation system predicts interference risks in advance
  Adaptive processing: real-time adjustment of cutting parameters (precision fluctuation
  Clamping benchmark:
  Use special fixtures to ensure the consistency of the positions of the two workpieces
  It is recommended to use hydraulic clamping (pressure stable at 0.6MPa)
  Tool management:
  Dual spindle tool length difference
  It is recommended to configure a tool life monitoring system
  Maintenance cycle:
  Daily: Check the lubrication condition of the guide rails
  Monthly: Calibrate the concentricity of the spindle
  Quarterly: Replace the screw bearing grease
