Product Inspection and On-spot Tests
发表于:昨天 12:19|本帖共 854 字 1460
       JINPAT has been adhering to the philosophy of “quality first”, and slip ring inspection has further strengthened the trust and credit between clients and itself.
   This week, one of our clients has set his schedule in JINPAT facility to check and accept the slip ring assembly. The unit completed is a military part that embodies a challenging technology on a compact-designed capsule slip ring. It integrates a hybrid transmission of electricity & signals including Ethernet and video signal.
   On-spot tests covering simulation test, high & low temperature test, vibration and impact test.
  Together with other check and tests, all indexes have indicated an expected performance.
  Here is its outstanding performance:
  Circuits: 3ckt*6A, 4ckt *3A, 3ckt*0.1A, 7ckt *signal, 3ckt*video, 6ckt*SPI, 6ckt*Ethernet, 4ckt*SSI
  Working Temperature: -40~+80℃
  Life: 84 million revolutions
  From its appearance, its wire outlets and terminals has been designed to meet the requirements of actual installation.
