When to Replace Brake Linings: Thickness Standards & Warning Signs
发表于:7 天前|本帖共 3,757 字 2104
       Content
  A squeal on the first brake application of the morning usually means nothing. A squeal that persists through every stop is a different story — it's the wear indicator scraping against the drum, telling you the friction material is running out. Push past that stage and the sound changes to a harsher, metallic grind, which means the lining is gone and the shoe is cutting into the drum itself.
  Noise isn't the only tell. Longer stopping distances, a brake pedal that needs more pressure than it used to, or a truck that pulls to one side under braking all point to uneven or advanced lining wear. Vibration through the pedal or steering wheel often follows, caused by a drum or rotor that's been scored by metal-on-metal contact.
  Dashboard warning lights and lining wear sensors catch some of this automatically on newer equipment, but for drum brakes on commercial axles, a physical inspection still tells you more than any sensor.
  Guesswork has no place here — there are hard numbers. Under FMCSA rules, federal regulations on commercial vehicle brake lining thickness set the floor at 6.4 mm (1/4 inch) at the shoe center for non-steering air drum brakes, or the point where the lining reaches its wear indicator. Steering axle linings with a continuous strip can't go below 4.8 mm. Once a lining crosses that line, the vehicle is out of service, not just due for maintenance.
  Measuring correctly matters as much as knowing the number. A caliper reading at the shoe center is the most reliable method; a visual check should compare lining thickness to the height of the rivet heads securing it to the shoe. If the lining sits flush with or below the rivets, replacement is overdue, not upcoming.
  Many fleets set their own replacement point above the legal minimum — often closer to 3/8 inch — so a truck never gets caught mid-route with linings at the regulatory edge.
  Riding a lining down to bare metal doesn't just cost you the shoe. Metal-on-metal contact scores the drum, and a scored or heat-checked drum often needs machining or replacement — turning a routine reline into a much larger repair bill.
  On S-cam drum brakes, worn linings and the extra clearance that comes with them raise the risk of S-cam turnover, where the cam rotates past its intended range and the brake stops working effectively on that wheel end. Combine that with uneven wear across an axle and you get a truck that pulls under braking exactly when you need it to stop straight.
  None of this shows up gradually and then stabilizes. Wear accelerates once the lining thins, because there's less material to absorb heat and pressure — so a truck that seemed fine on Monday can be in genuinely unsafe territory by Friday.
  Not every truck wears its linings on the same schedule. Loaded weight is the biggest variable — a tractor running near GVWR on a downgrade generates far more heat and friction load than the same truck running empty on flat highway.
  Oil or grease contamination deserves its own mention, since it's often mistaken for a lining problem when it's actually a seal problem. If contamination covers more than about 10 percent of the lining surface, cleaning it isn't a safe fix — the shoe needs to come off and the actual leak needs to be found.
  Swapping one worn shoe and leaving its partner in place is a common shortcut — and a poor one. Braking is a balanced system: linings on both ends of an axle need matched friction characteristics to stop the vehicle evenly.
  Mixing a fresh lining against a half-worn one on the same axle changes how each wheel grabs, which can pull the truck to one side under hard braking. The safer approach is to replace brake shoe assemblies as a complete axle set, along with related wear items like return springs and cam bushings while everything is already apart.
  This is also the point to inspect the drum itself — a good set of new linings won't perform properly against a drum that's out of round or scored beyond tolerance.
  Once the decision to replace is made, material and fit matter as much as timing. Heavy-duty axles need drum brake linings built for sustained high-temperature loads, rather than passenger-car friction compounds that glaze or fade under repeated heavy braking.
  Matching the lining to the axle manufacturer keeps geometry and friction performance within spec — BPW axle linings, Volvo drum brake linings, and <a href="/product/drum-brake-lining/mercedesbenz/" style="color: #0066cc; font-weight: bold; font-style: italic; text-decoration:
