The Widely Used B/D Form Tie System
发表于:2026-11-7 13:42:28|本帖共 727 字 4222
       Form tie system is widely used in the construction industry, it is fast and easy to assemble and remove.The system prevents breakage in the formwork construction and keeps concrete structures in good shape. It can save construction costs, as all parts are reusable except for the separator (inner unit) which is caste into the concrete structures. There are four types:B Type,C Type, BC Type and D Type. Hot sale products are B Form Tie System and D Form Tie System.
  B/D formtie and inner unit are made of carbon steel. Dia9mm and Dia12mm are available. Inner unit is used to measure the wall thickness and it will be left in the wall after concrete pouring. But form tie can be reused for next project.
  These hardware for form tie are mainly delivered to Southeast Asia, like Singapore, Malaysia, Thailand, Indonesia, Myanmar, etc.
  We Hebei Trico supply all these hardwares.
