Steel Tie Rod for Formwork Tie Rod System
发表于:2026-10-18 11:08:38|本帖共 628 字 2163
       Cold-rolled steel tie rod is one kind of concrete tie rod. It is made of steel #45 or Q235 with different diameters.
  A lot of related accessories are available, such as hot-rolled tie rod, wing nut, tie nut, hex nut, connection nut, water stop, formwork clamp, steel cone, etc.
  All of the tie rods and related accessories are applicable to all kinds of concrete formwork & shuttering systems.
  The cold-rolled tie rods are threaded from a steel round bar structure. The different steel structure grade makes the concrete tie rods with different breaking loads. Take the D15(15/17mm) tie rod for example:
  The ultimate rest result of D15 concrete tie rod by Steel grade Q235: 95Kn
  The ultimate rest result of D15 concrete tie rod by Steel grade #45: 145Kn
