What does a smart switch for household appliances look like?
发表于:2026-10-16 09:25:34|本帖共 1,259 字 4933
       Thinking of "smart home, smart life", the best impression in our hearts is definitely that it is fully automated, without you worrying about it, and there are smart robots to take care of you. Although this illusion is getting closer and closer to us, smart homes today also have many pain points that cannot be ignored.
  The function management is not centralized enough, the product functions are too different, and the interaction is rigid. In addition, the number of smart home manufacturers in the future will become more fragmented and more fragmented. Diversification.
  What exactly is a smart switch? What is the difference between this and the "smart gateway" that everyone knows? "Smart gateway" (or AI speaker) is mainly to uniformly control smart devices of its own brand, and passively accept instructions. The smart switch is a smart hub, not only can control smart devices of its own brand, but also supports device access of WiFi, Bluetooth, and Zigbee. , It is equivalent to include all the functions of "panel switch" + "smart gateway" + "smart speaker".
  The smart switch adopts an embedded design, the size of the national standard double 86 bottom box, 220V zero live wire power supply, can easily adapt to the current home decoration, network cables and other cables can be completely hidden in the wall through the back box of the fuselage, not only ensuring the appearance Face value, the network will be more stable.
