LEM电池监控状态监测 状态监测 LEM的电池监控解决方案是一个完整的解决方案,包括一系列组件,能够简单快速的安装,该方案包括以下组件: Sentinel:可以测量单个VRLA电池或富液式电池的电压,温度和内阻,通过专属总线S-BUS传送给数据记录器S-BOX。 电流传感器:电流传感器检测电池组的状态(充电,放电或者浮充状态)。 S-BUS Converter:该模块将S-BUS协议转换成标准的串行输出协议。 S-BOX:带有Ethernet接口的数据记录装置,用来记录每一个Sentinel的趋势和报警。 Cellview Net:和S-BOX配合使用的可视化软件,用于图形化显示各种数据,报警以及生成各种报告。 蓄电池监控的重要益处 莱姆的蓄电池监测解决方案能够从两个方面为您带来收益: 蓄电池维护服务 系统的安装和调试 蓄电池维护 单个蓄电池的参数监测 (温度, 电压, 内阻) 正确的参数测量可以极大地减少电池的失效事故 网络化分布与“向导式”软件 节约时间: 使安装和调试更加快捷 远程监测单元 存储及保护数据,支持多站点数据远程监控 监测软件 简单的数据图形化软件可帮助决策者做出正确的决策 LEM电池监控状态监测 系统组件 System components for battery monitoring Sentinel S-Box Cellview net software Accessories Sentinel Technical data: One Sentinel per monobloc/cell Measures the voltage, temperature, and impedance of the bloc Sentinel voltage range from 0.9 to 16V Daisy chain communication to the S-BOX for up to 254 Sentinel Din rail mounting S-Box Technical data: Communicates with 254 Sentinels 6 strings/current transducers + ambient temperature probe LAN and internet connection Different ‘modes’ of operation, reflecting different battery status: Normal / Discharge / Recharge Minimum of 5 weeks of data storage (without discharge) Easy commissioning software “Wizard like” (SIMS) Graphical viewer software (Cellview net) Daily logs (configurable) Alarms & Weekly reporting Cellview Net Software A software battery management tool that provides information on each of the cell for the user to manage the performance of the battery and scheduling the maintenance programs. The Benefits: Greatly reduces the time required to review battery data Allows for easy graphical analysis and data interpretation A planning tool for scheduling maintenance work Saves money in reduced staffing required to gather the system data
