Delivery Of Guillotine QC11Y-16x6000
发表于:2026-10-12 14:23:52|本帖共 612 字 1063
       Delivery of guillotine QC11Y-
  The guillotine shearing machine adopts all-steel welding of frame structure;
  four-corner and eight-sided right-angle guide rail, high precision, good rigidity,
  and adopts hydraulic preload. The hydraulic system adopts a two-way cartridge integrated valve; the entire system adopts;
  and can be equipped with stroke digital display, photoelectric protection device and mobile workbench (for easy replacement of molds),
  guillotine shears have double action of upper slide and lower hydraulic cushion Function, the working pressure stroke can be adjusted within the specified range according to the process requirements,
  and the operation is simple and centralized control by buttons.
