Join Us | The Utility Expo 2025 in Louisville, USA
发表于:2026-10-4 11:32:26|本帖共 1,473 字 3167
       The highly anticipated global gathering of the construction equipment industry—The Utility Expo 2025 in Louisville, USA—is about to commence! Shandong Hightop Group cordially invites you to visit our booth to explore cutting-edge industry trends and witness our innovative products and solutions.
  Exhibition Name: The Utility Expo 2025
  Booth Number: Indoor S4542
  Event Dates: October 7–9, 2025
  Venue: Kentucky International Convention Center, USA
  As a specialized manufacturer in the small-to-medium construction equipment sector, Hightop Group will showcase its flagship products, including but not limited to:
  HT18 Excavator:
  Equipped with Kubota/Koppe engines delivering 10.2 kW rated power, offering reliable performance and outstanding fuel efficiency.
  Features 75°/45° swing angles on both sides for tight corner operations.
  With a transport width of just 1.1m, 30° gradeability, and 119mm ground clearance, it easily navigates standard doorways and narrow passages.
  HT360 Loader:
  8.5kW robust power effortlessly conquers muddy slopes.
  17MPa high-pressure system accelerates post-storm debris clearance and dam repairs.
  Customized tracks ensure rock-solid stability on muddy inclines.
  HT750 Mower:
  Covers 2000㎡ in one hour for lightning-fast orchard weed removal.
  300m remote control range + 360° on-the-spot turning for effortless navigation in complex terrain.
  Professional track design ensures rock-solid stability on slopes and rugged surfaces.
  We look forward to welcoming you at Booth S4542!
  Our expert team will provide detailed product demonstrations and business consultations. Experience Hightop Equipment's precision engineering firsthand and discover how we can empower your operations.
