Denison Vane Pump T6ED
The high-pressure single vane pump has the ability to achieve high working pressure in a compact size, ensuring a high power-to-weight ratio and reducing installation costs. It is widely used in injection molding machines, die-casting machines, hydraulic presses, marine machinery, construction machinery and other machinery industries.
Denison Double Vane Pump T6ED Features:
▲High pressure, low noise, high efficiency.
▲The working pressure of Denison oil pump is as high as 275Bar. If the working pressure is reduced, the working life of the oil pump can be extended!
▲High volumetric efficiency
▲Reduce heat generation and reduce the operating cost of hydraulic equipment.
▲High mechanical efficiency, thus reducing energy consumption.
▲The speed range is wide, the speed range is 600-2800rpm
▲Strong anti-pollution ability, the Denison oil pump adopts the vane with double lip structure, which has strong anti-pollution ability
▲Long service life. Suitable for a wide range of viscosity of hydraulic media
▲Can start at low temperature and run at high temperature
1. High efficiency and energy saving: This vane pump has the characteristics of high efficiency under low pressure. By reducing external oil leakage, the pressure balance can achieve the best effect, further reducing heat generation and improving efficiency. Therefore, effects such as energy saving of the oil pump and improvement of machining accuracy can be produced.
2. Light weight and miniaturization: Because the pump and motor are designed as a special combination of pump and motor, they are light in weight, small in size, easy to operate, and expand the scope of use.
3. Low noise and long service life: Because the oil pump and the motor shaft are connected with a special joint, they will not be affected by the vibration of the shaft and the dislocation of the shaft core, and the noise is lower. In addition, due to the structure, the connecting part can be lubricated by oil frequently, so the bearing will not be subject to friction loss, and the service life is increased.
