北京莱普特新品推荐——四联加热磁力搅拌器
发表于:2026-9-29 13:41:46|本帖共 2,034 字 3208
       MS-4A四联加热磁力搅拌器 4 Heads Magnetic Stirrer
  MS-4A四联磁力搅拌器采用特制搪瓷盘加热技术,表面温度可达到340℃。磁力搅拌子搅拌技术,人性化操作设计,可满足多种加热搅拌实验需求。
  4 Heads Magnetic Stirrer has single-point and multi-point simultaneous stirring function, with mechanical timing, easy operation and stepless speed regulation, which can stably and precisely stir the liquid in a wide range. It is a common tool in petroleum, chemical industry, medical and health, environmental protection, biochemical laboratories, analysis rooms, and education departments.
  1. 四个加热盘面独立控温控速,独立显示。
  2. 外壳采用金属外壳,高强度,耐高温,防腐蚀。
  3. 控温采用PID控制算法,数字显示,精度高,冲温小(±5℃以内),内、外PT1000测温。
  4. 可对50ml~2L×4标准或非标准反应瓶进行加热或搅拌。
  5. 直流无刷电机,性能稳定,噪音小,寿命长,无火花产生。
  6. 采用搪瓷加热面盘加热,表面温度可达到340℃。
  7. 30°斜面操控面板适合坐位和站位视角。
  8. 磁力搅拌技术,低速平稳,高速强劲。
  1. Four heating plates independently control temperature and speed, independent display.
  2. The outer casing is made of metal, with high strength, high temperature resistanceand corrosion resistance.
  3. The temperature control adopts PID control algorithm, digital display, high precision, small flushing temperature (within ±5°C), and internal and external PT1000 temperature measurement.
  4. Can heat or stirre 50ml~20L standard or non-standard reaction bottles.
  5. Brushless DC motor, stable performance, low noise, long life and no sparks.
  6. Heated by an enamel heating plate and the maximum surface temperature can reach 340 °C.
  7. The 30° bevel control panel is suitable for sitting and standing angles.
  8. Magnetic stirring technology, stable at low speed, strong at high speed.
  型号
  MS-4A
  工作盘尺寸
  Φ137mm
  工作盘盘面材料
  搪瓷
  转速范围
  200~1200rpm
  控温范围
  室温+5℃~340℃
  温度设定范围
  30℃~340℃
  温度稳定性
  ±3℃
  搅拌点位数量
  搅拌量(H2O)
  2L×4
  标配搅拌子尺寸
  Φ8×46mm
  外接温度传感器
  PT1000
  可调安全温度回路最小值
  50℃
  可调安全温度回路值
  350℃
  输入电源
  AC220V 50/60Hz
  功率
  1600W
  熔断器
  250V ,10A,φ5×20
  外形尺寸(W x D x H)
  W.610×D.272×H.86mm
  净重
  8.5Kgs
  Model
  MS-4A
  Platform Size
  Φ137mm
  Platform Material
  enamel
  Speed Range
  200~1200rpm
  Temp. Control Range
  R.T.+5℃~340℃
  Temp. setting range
  30℃~340℃
  Temp. stability
  ±3℃
  Stirring Point Quantity
  Max. stirring capacity(H2O)
  2L×4
  Standard size of stirring bar
  Φ8×46mm
  External temp. sensor
  PT1000
  Adjustable safety min. temp. loop
  50℃
  Adjustable safety max. temp. loop
  350℃
  Voltage
  AC220V 50/60Hz
  Power
  1600W
  Fuse
  250V ,10A,φ5×20
  Dimension
  W.610×D.272×H.86mm
  Net weight
  8.5Kgs
