Hydroxypropyl methyl fiber is an important water-soluble polymer cellulose ether. Due to its excellent performance, it is reflected in food, chemical, coating, ink printing, plastics and other industries Applications.
1. Application in chemical industry, it can be used as emulsifying aid in the polymerization of vinyl chloride, and as a dispersant in the polymerization of polyurea
2. Coating industry: It can be used as a masking agent on electrical instruments in the coating industry. It can also be used as an iron and steel coating component. After being treated with silicate, it can prevent corrosion and thicken in the coating industry. Agents, dispersants and stabilizers have good compatibility in water or organic solvents. As a paint remover.
3. Ink printing: as thickener, dispersant and stabilizer in the ink industry, it has good compatibility in water or organic solvent
4. Plastic: used as a mold release agent, softener, lubricant, etc. |
