Revealing the 8 core processes of the strand cooling pelletizing line
发表于:2026-9-13 12:29:04|本帖共 2,388 字 2645
       🚀 Strand Cooling Pelletizing Line♻️
  This equipment is suitable for recycling and granulating a variety of hard plastics,
  such as ABS, PC, PP, PE, etc., providing efficient and stable solutions for the plastic
  recycling industry.
  1️⃣ Raw material transportation
  The recycled plastic is evenly fed into the extruder feed port by a belt conveyor to achieve
  a stable and efficient feeding process. The automatic conveying system reduces manual
  intervention, improves the continuity and automation level of production, and reduces the
  intensity of manual labor.
  2️⃣Melt extrusion
  The plastic enters the single screw extruder and undergoes heating, plasticization, extrusion
  and other processes to make it fully melted and evenly extruded.
  🔹High-efficiency barrel + optimized screw design: better plasticization effect, ensuring
  high output and low energy consumption.
  🔹Wear-resistant alloy material: The core components of the equipment are made of
  high-wear-resistant alloy, and the service life is 1.5 times longer than that of ordinary materials.
  🔹Screw material: Made of high-quality nitrided steel 38CrMoAIA, after nitriding treatment,
  it has the characteristics of corrosion resistance, wear resistance, and high temperature
  resistance, which greatly improves the stability and durability of the equipment.
  3️⃣Screen changer filtration
  The molten plastic passes through the screen changer to effectively filter impurities and
  ensure the purity of the particles, thereby improving the quality of the recycled material.
  ✅Efficient filtration to improve particle quality
  ✅Reduce equipment wear and maintenance costs
  ✅Extend equipment life and improve production efficiency
  4️⃣Cooling and shaping
  After the molten plastic is extruded from the die head, it forms a uniform material strip and
  enters the cooling water tank, where it quickly cools down and solidifies to maintain a stable
  strip shape. The water tank temperature and water flow rate can be adjusted to meet the
  cooling needs of different materials.
  5️⃣Strand pelletizing
  🔹The cooled plastic strips enter the strand pelletizer and are precisely cut into particles
  of uniform size.
  6️⃣Vibrating screen screening
  The plastic particles after pelletizing are screened through a vibrating screen to remove
  dust, oversized or undersized particles, ensuring uniform particle size and stable quality
  of the finished product.
  7️⃣Wind conveying
  Qualified particles are quickly transported to the storage link through wind conveying
  equipment, which not only improves production efficiency, but also avoids secondary
  pollution and ensures the cleanliness of the particles.
  8️⃣ Final storage
  The final plastic particles enter the storage silo, providing convenient storage for
  subsequent packaging or direct application.
  Contact Us!
  Video:
