As an increasing number of people are pursuing an energy-saving and environmental-friendly lifestyle, the application of LOW-E glass and coated glass become universally popular. Therefore, most of the insightful glass manufacturers are seeking compatible solutions to process LOW-E glass. Glass double edging, glass washing and drying, glass tempering and other related process require superior technical arrangement.
Today, let us focus on the glass double edging and washing solution for LOW-E glass with one of our recent customized project cases.
The automatic glass double edging and washing production line is used to grind the parallel glass edges and to remove the border film on the LOW-E glass surface.
Highlight: Flexible grinding structure; LOW-E glass applicable; Highly automation
Two parallel synchronous working stations, five grinding spindles each side, and a combination of different design of spindle bases. These arrangement enables the equipment to process up and down arris, pencil edge (or flat edge if using suitable wheels) and remove LOW-E film (or make grooves).
In the insulating glass processing industry, removing the film along the edges is a common requirement in order to improve the lifespan and performance of the coated glass.
For the glass double edging machine, the upper timing belt is specially designed and able to clamp and convey the LOW-E glass without damaging the surface film.
While for the glass washing and drying machine, one of the washing brushes adopts soft material and thus able to clean the LOW-E glass efficiently and protectively. Thanks to the intelligent PLC system, user only needs to choose the LOW-E type and the machine will switch to the specific working mode.
To most factory owners who process medium-and-small-sized glass for the home appliances industry and household industry, efficiency and productivity are undoubtedly important.
We arrange an automatic glass loading robotic arm at the beginning of the production line. With the quality suction cups, it can find, pick up, and load the glass onto the inlet of the double edging machine automatically and continually.
We LIAODA(LAD) devotes to satisfying clients’ production requirement by providing customized glass processing solutions. If you want to know more about our project cases, don’t hesitate to contact our sales team!!
