KINGMAX CELLULOSE: 15+ Years of HPMC Manufacturing Excellence for Mortar & Gypsum
发表于:2026-9-7 08:03:49|本帖共 836 字 1634
       HPMC for mortar and gypsum requires deep understanding of:
  You don’t learn these overnight. 15+ years means we’ve solved thousands of formulation challenges.
  Consistent viscosity – ±5% batch to batch (not ±15%) High purity – ≤5% ash, ≤8% moisture Technical support – Formulation advice from experienced chemists Reliable supply – 15,000+ tons annual capacity
  “We tested HPMC from seven suppliers. KINGMAX gave the best water retention for our gypsum plaster at the most competitive price. We’ve been buying from them for 3 years now.” — Gypsum Product Manufacturer, Poland
  “Their technical team helped us reduce HPMC dosage by 15% without losing open time. That’s real expertise.” — Tile Adhesive Producer, Egypt
  Not sure which HPMC grade works best for your mortar or gypsum product?
  Send us your:
  Our chemists will recommend the optimal grade and dosage – free of charge.
