What Are The Production Types And Machining Allowances In Precision Machining?​
发表于:2026-9-5 08:04:18|本帖共 2,014 字 1176
       What are the production types and machining allowances in precision machining?
  Production type
  Production types are usually divided into three categories.
  1. Single-piece production To produce a part individually and rarely repeat production.
  2. Mass production The production of the same parts in batches.
  3. Mass production When the number of products manufactured is large, most workplaces often repeat the production of a certain process of a part. When drawing up the process of parts, due to the different production types of parts, the processing methods, machine tools, tools, fixtures, blanks and technical requirements for workers are very different.
  Machining allowance
   In order to process qualified parts, the thickness of the layer of metal that must be cut from the blank is called the machining allowance. Machining allowance can be divided into process allowance and total allowance. The thickness of the metal layer that needs to be removed in a certain process is called the machining allowance of the process. The total margin that needs to be removed from the blank to the finished product is called the total margin, which is equal to the sum of the margins of each process on the corresponding surface.
  The purpose of leaving a machining allowance on the workpiece is to remove the machining errors and surface defects left by the previous process, such as the chilled layer, pores, sand layer on the surface of the casting, and the scale, decarburized layer, and surface cracks on the surface of the forging , The internal stress layer and surface roughness after cutting. Thereby improving the accuracy and surface roughness of the workpiece.
  The size of the machining allowance has a great influence on the processing quality and production efficiency. Excessive machining allowance not only increases the labor of mechanical processing and reduces productivity, but also increases the consumption of materials, tools and power, and increases the processing cost. If the machining allowance is too small, the defects and errors of the previous process cannot be eliminated, and the clamping errors during the processing of this process cannot be compensated, resulting in waste products. The selection principle is to make the margin as small as possible under the premise of ensuring quality. Generally speaking, the more finishing, the smaller the process margin.
