ChunYe Technology | New Product Analysis: Portable Analyzer
发表于:2026-9-1 10:11:58|本帖共 2,993 字 1174
       Water quality monitoring is one of the primary tasks in environmental monitoring. It accurately, promptly, and comprehensively reflects the current status and trends of water quality, providing a scientific basis for water environment management, pollution source control, environmental planning, and more. It plays a crucial role in protecting water environments, controlling water pollution, and maintaining water health.
  Shanghai ChunYe adheres to the service philosophy of "striving to transform ecological environment advantages into eco-economic advantages." Its business scope mainly focuses on the research, production, sales, and service of industrial process control instruments, online water quality automatic analyzers, VOCs (volatile organic compounds) online monitoring systems, TVOC online monitoring and alarm systems, IoT data acquisition, transmission and control terminals, CEMS flue gas continuous monitoring systems, dust and noise online monitors, air monitoring, and other related products.
  Product Overview The portable analyzer consists of a portable instrument and sensors, requiring minimal maintenance while delivering highly repeatable and stable measurement results. With an IP66 protection rating and ergonomic design, the instrument is comfortable to hold and easy to operate even in humid environments. It comes factory-calibrated and requires no recalibration for up to a year, though on-site calibration is possible. The digital sensors are convenient and quick for field use, featuring plug-and-play functionality with the instrument. Equipped with a Type-C interface, it supports built-in battery charging and data export. It is widely used in aquaculture, wastewater treatment, surface water, industrial and agricultural water supply and drainage, domestic water, boiler water quality, scientific research, universities, and other industries for on-site portable monitoring.
  Prduct Size
  Product Features
  1.Brand-new design, comfortable grip, lightweight, and easy operation.
  2.Extra-large 65*40mm LCD backlit display.
  3.IP66 dustproof and waterproof rating with ergonomic curve design.
  4.Factory-calibrated, no recalibration needed for a year; supports on-site calibration.
  5.Digital sensors for convenient and fast field use, plug-and-play with the instrument.
  6.Type-C interface for built-in battery charging.
  Performance Specifications
  Housing Material Sensors: SUS316L + POM; Host housing: PA + fiberglass
  Storage Temperature -15 to 40°C
  Operating Temperature 0 to 40°C
  Host Dimensions 235 × 118 × 80 mm
  Host Weight 0.55 kg
  Protection Rating Sensors: IP68; Host: IP66
  Cable Length Standard 5-meter cable (extendable)
  Display 3.5-inch color screen with adjustable backlight
  Data Storage 16 MB storage space (approx. 360,000 datasets)
  Power Supply 10,000 mAh built-in lithium battery
  Charging & Data Export Type-C
  Maintenance & Care
  1.Sensor exterior: Rinse the sensor’s outer surface with tap water. If debris remains, wipe it with a damp soft cloth. For stubborn stains, add a mild detergent to the water.
  2.Check the sensor’s measurement window for dirt.
  3.Avoid scratching the optical lens during use to prevent measurement errors.
  4.The sensor contains sensitive optical and electronic components. Ensure it is not subjected to severe mechanical impact. There are no user-serviceable parts inside.
  5.When not in use, cover the sensor with a rubber protective cap.
  6.Users should not disassemble the sensor.
