1、 Regular inspection and maintenance
1. Check LGMG telehandler the battery: The power source of electric forklifts is the battery, and it is crucial to regularly check the status of the battery. Ensure that the battery is fully charged, check if the battery connections are secure, and avoid corrosion.
2. Check tires: Tires are the sany thelehander part of the forklift that comes into contact with the ground. Check the tire pressure, wear level, and whether there are any foreign objects embedded.
3. Check the mlt 740 thelehander hydraulic system: The hydraulic system is crucial for forklift lifting and cargo handling. Regularly check the hydraulic oil level, filter, and quality of the hydraulic oil.
4. Check the TLH1242 telehandler braking system: The braking system ensures the kingway telehandler safety and reliability of the forklift during handling, checks the wear of the brakes to ensure braking effectiveness. www.haiqinmachinery.com |
