ASTM D5894-16测试标准
发表于:2026-8-24 13:22:09|本帖共 1,780 字 4001
       本页面标准信息均来源于网络收集,或由参与标准制定的供应商提供,只作为参考使用,为确保测试结果的准确性、节省您的时间,如需ASTM D5894-16标准详细信息或ASTM D5894-16具体测试方法,欢迎与我们技术人员联系或给我们留言,我们将为您相关的技术支持。
  ASTM D5894-16标准介绍
  ASTM D5894-16英文简介
  1. ASTM D5894-16Scope
  1.1 This practice covers basic principles and operating practice for cyclic corrosion/UV exposure of paints on metal, using alternating periods of exposure in two different cabinets: a cycling salt fog/dry cabinet, and a fluorescent UV/condensation cabinet.
  1.2 This practice is limited to the methods of obtaining, measuring, and controlling exposure conditions, and procedures. It does not specify specimen preparation nor evaluation of results.
  1.3 The values stated in SI units are to be regarded as standard. No other units of measurement are included in this standard.
  1.4 This standard does not purport to address all of the safety concerns, if any, associated with its use. It is the responsibility of the user of this standard to establish appropriate safety and health practices and determine the applicability of regulatory limitations prior to use.
  2. Referenced Documents
  ASTM Standards
  D610 Practice for Evaluating Degree of Rusting on Painted Steel Surfaces
  D714 Test Method for Evaluating Degree of Blistering of Paints
  D1654 Test Method for Evaluation of Painted or Coated Specimens Subjected to Corrosive Environments
  D4587 Practice for Fluorescent UV-Condensation Exposures of Paint and Related Coatings
  G85 Practice for Modified Salt Spray (Fog) Testing
  G113 Terminology Relating to Natural and Artificial Weathering Tests of Nonmetallic Materials
  G147 Practice for Conditioning and Handling of Nonmetallic Materials for Natural and Artificial Weathering Tests
  G151 Practice for Exposing Nonmetallic Materials in Accelerated Test Devices that Use Laboratory Light Sources
  G154 Practice for Operating Fluorescent Ultraviolet (UV) Lamp Apparatus for Exposure of Nonmetallic Materials
  Q-fog CRH盐雾试验箱用于ASTM D5894-16的测试方法
  ▼ASTM D5894-16第三方检测机构
  以上标准信息来自互联网搜索整理,如需了解完整的ASTM D5894-16的信息或ASTM D5894-16标准解读,欢迎详询。
