阀门材料术语中英文对照表
发表于:2026-3-22 13:55:45 3669
       Buna-N rubber 丁晴橡胶 Casting aluminium brass 铸铝黄铜 Casting aluminium bronze 铸铝青铜 CHR rubber 氯晴橡胶 Chrominm-molybdenum-vanadium steel 铬钼钒钢 Chromium stainless steel 铬不锈钢 Chromium-molybdenum steel 铬钼钢 Corrugation pad 波形垫 Cuprum alloy 铜合金 Ductile Cast iron 球墨铸铁 Expanded graphite 柔性石墨 Fine Steel Casting iron 碳素钢 Fluorous rubber 氟橡胶 Gray Cast iron 灰铸铁 Hayne’s alloy 钴铬钨合金 High tem perature steel 高温钢 Low tem perature steel 低温钢 Nylon 尼龙塑料 Polytetrafluoroethylene 聚四氟乙烯 Pure aluminum 纯铝 Pure cupper 纯铜 Rubbeer graphite board 橡胶石墨板 Spring steel 弹簧钢 Stainless acid-resisting steel 不锈耐酸钢 Stainless and Graphite 不锈钢/石墨 Stainless steel 不锈钢 Steel Casting iron 碳素钢铸件 Shell Test Pressure 壳体试验压力 Service Fluid 工作介质
支持
2026-4-25 11:05:02 回复
内容很好
4 天前 回复
