转化生长因子α(TGFα)多克隆抗体
发表于:2026-2-27 10:16:21 674
       转化生长因子α(TGFα)多克隆抗体
  Polyclonal Antibody to Transforming Growth Factor Alpha (TGFa)
  FOR IN VITRO AND RESEARCH USE ONLY, NOT FOR USE IN CLINICAL DIAGNOSTIC PROCEDURES!
  转化生长因子α(TGFα)多克隆抗体 ANTIBODY SPECIFITY
  The antibody is a rabbit polyclonal antibody raised against TGFa. It has been selected for its ability to recognize TGFa in immunohistochemical staining and western blotting.
  APPLICATIONS
  Western blotting: 1:100-400 Immunocytochemistry in formalin fixed cells: 1:100-500 Immunohistochemistry in formalin fixed frozen section: 1:100-500 Immunohistochemistry in paraffin section: 1:50-200 Enzyme-linked Immunosorbent Assay: 1:100-200 Optimal working dilutions must be determined by end user.
  转化生长因子α(TGFα)多克隆抗体 CONTENTS
  Form & Buffer: Supplied as solution form in PBS, pH7.4, containing 0.02% NaN3, 50% glycerol.
  IHC Images
  转化生长因子α(TGFα)多克隆抗体 STORAGE
  Store at 4oC for frequent use. Stored at -20oC to -80oC in a manual defrost freezer for one year without detectable loss of activity. Avoid repeated freeze-thaw cycles.
这个资料太有用了
2026-3-30 02:13:01 回复
支持楼主
2026-3-30 06:07:05 回复
2026-5-21 05:58:57 回复
