螺杆泵的基本工作原理
发表于:2026-2-20 08:47:35 2101
       其工作原理是当电动机带动泵轴转动时,螺杆一方面绕本身的轴线旋转,另一方面它又沿衬套内表面滚动,于是形成泵的密封腔室。螺杆每转一周,密封腔内的液体向前推进一个螺距,随着螺杆的连续转动,液体螺旋形方式从一个密封腔压向另一个密封腔,最后挤出泵体。螺杆泵是一种新型的输送液体的机械,具有结构简单、工作安全可靠,使用维修方便、出液连续均匀、压力稳定等优点。 Its working principle is that when the motor drive shaft rotates, screw on the one hand around its own axis of rotation, on the other hand it rolling along the inner surface of bush, so the formation of a sealed pump chamber. Screw week per revolution, the liquid seal chamber to move forward one pitch, with the continuous screw rotation, the liquid spiral way from a sealed chamber pressure, sealed chamber to another, and finally out of pump body. Screw pump is a new type of liquid delivery of machinery, with a simple structure, safe and reliable use of easy maintenance, a continuous uniform fluid, pressure, stability and so on.
2026-3-23 09:50:49 回复
