去除木屑的筛选方法--旋振筛
发表于:2026-7-12 13:55:27|本帖共 3,742 字 1463
       Sawdust is usually produced in chipping process of wood powder mixed with wood chips orsawdust in the sawmill some operation process, is the need to remove the components in prior to pulping. The traditional method is to configure different sieve mesh layer vibration sieve(rotary screen) in the treatment of rotary screen, some limitations led to the development of other technologies, including now used for roll screen. These new technologies include a lot of technological innovation, the application range is more extensive, wood chip removal and some other screening method.
  Rotary screen
  Rotary screen loading typical, sawdust and wood chips will be poured directly on the screen andthe feed end level, falling fast rotating movement of material level make piles of wood spreadinto a certain angle, screening machine installation of the material along the screen layer sliding down to the sawdust layer of screening. When the chips met the right mesh will in the course of screening by, and not through the big wooden and large chips continue to run forward along thescreen layer. As long as the sieve plate is not broken, screening out the wood size should befairly uniform, and the sieve
  Size consistent. Rotary screen is feasible, because this is essentially a debris near the meshproblem, is the probability of debris encountered suitable sieve size, carefully observe the writing of the scientists of the process mentioned in the paper -- whether it is possible to work out anydebris encountered and through a suitable opening sieve probability, the theory is used to calculate the wood processing industry rotary screening and application of "conventional wisdom" factor, the results showed that two were surprisingly consistent. Debris not on the sieve plate sieve effect factor and found there were usually several, the first is from other similar sizeand larger materials competition. This may be a simple loading rate problem -- as long as youcan provide enough opportunity to get close to the plate for competitive debris, so screening machine will have adequate screening ability.
  On the sieve plate to form a specific pattern is very important in the flow of good fluidity, aturbulent state, a lot of big size material does not obstruct the wooden needle arrived in thesieve surface. In order to achieve this kind of fluidization, screening machine need speed andfrequency of some typical traditional screen, speed is 180 r/min, the speed at which, material
  Flow is likely to plug flow like running without the formation of ideal. Screening machineoperating speed at present is 235 ~ 300 r/min, the high frequency and motion amplitudeadjustment to create flow conditions required. There is some relationship between the sievebody of the operation speed and amplitude, slow speed rotating sieve body usually larger radius, high speed screen rotation amplitude is very small,
  This drive to balance block system driven by screening and control of the centrifugal force isvery necessary. The sieve body rotation speed, small amplitude, the screening effect is good;and the screen body rotation speed is slow, but there must be sufficient amplitude, screeningeffect can still. The majority of the sawmill, a screening machine also has fine screen and screenthese two functions. The tilt angle of the sieve plate is almost 7 degrees to 8 degrees, and somewood products used in screening sieve cited stone, mineral screening using sieve. The miningsieve is 20 DEG to 25 DEG angle, when the sieve plate at an angle of 20 DEG to 25 DEG, woodis very short residence time in the sieve surface, thus affecting the efficiency of screening.Screening of wood products, old-fashioned screen usually have a heavy casting base orcombined base to generate offset screen basket to rotate in the process of. =++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ 相关产品推荐:
  XZS系列旋振筛产品概述 该系列 振动筛 的基本原理是利用电机轴上下安装的重锤(不平衡重锤),将电机的旋转运动转变为水平、垂直...
  WS系列气流筛分机摈弃重力势能作业原理,采用空气作载体,动能作功的作业原理。通过负压气流将物料与空气混合后,进入筛机风轮中...
  浆液专用过滤筛适用于陶瓷、食品、医药、化 工、电子、粉末冶金、塑料橡胶、研磨等行业中的粉、粒、液体的筛分、过滤,特别是对...
  过滤筛机型小巧,重量轻,可以任意移动,任何粒、粉、粘液皆可适用。...
  摆动筛是一种仿人工摇动的低频旋振筛,其原理是:瞬时运动为沿径向的位移和以此位移为轴的圆周运动的合成(螺旋运动)。...
  超声波振动筛是将220V、50Hz或110V、60Hz电能转化为18KHz的高频电能,输入,将其变成18KHz机械振动,从而达到高效筛分...
  本文关键词:
非常不错
2026-7-24 14:27:11|本帖共 4 字 回复
感谢分享!又一篇高质量好帖,感谢您!
2026-10-18 16:14:25|本帖共 18 字 回复
感谢分享!您不是在写帖子,是在写历史。
12 小时前|本帖共 19 字 回复
