1.独特电池仓设计,便于更换电池。
1. Unique battery bin design, easy to replace batteries.
2.“三防”功能:全密封设计,防水、防漏、防攻击。
2. "Three-proof" function: fully sealed design, waterproof, leak-proof, attack-proof.
3.可设定报警水量,当剩余水量达到报警值时,阀门自动关闭,液晶显示“购卡”、“关阀”,提醒用户购水,此时用户可再刷一次卡,即可使用剩余水量。若剩余水量为0m3时,阀门自动关闭,用户必须购水刷卡后方可开阀使用。
3. The alarm water can be set. When the residual water reaches the alarm value, the valve will automatically close. LCD displays "buy card" and "shut off valve" to remind the user to buy water. At this time, the user can brush the card again and use the residual water. If the remaining water is 0 m3, the valve closes automatically. Users must buy a water brush card before opening the valve.
4.即换即用功能:采用国家标准设计,连接尺寸与普通水表相同,无需改动管道即可更换。
4. Instant-to-use function: The connection size is the same as that of the ordinary water meter, which can be replaced without changing the pipeline, using the national standard design.
5.微功耗设计:静态工作电流小于6UA,保证电池使用寿命大于6年。
5. Micro-power design: The static working current is less than 6UA, which ensures that the battery life is longer than 6 years.
6.一卡通功能:该表支持一卡多表,可实现水、电、气、暖一卡通。
6. One Card Function: The meter supports one card and many tables, which can realize one card for water, electricity, air and heating.
7.阀门采用不锈钢浮动式电动球阀,压力损失小,开关阀门阻力小,耗电少。
7. The valve adopts stainless steel floating electric ball valve, which has low pressure loss, low resistance and low power consumption.
8.LCD液晶常显可用水量,累计用水量、阀门状态、电池状态等多种参数信息。
8. LCD liquid crystals often display the available water, accumulative water consumption, valve status, battery status and other parameters.
9.机芯部件采用ABS高强度工程塑料作为主要原料,性能稳定可靠,使用寿命长。
9. The core components are made of ABS high-strength engineering plastics, which have stable and reliable performance and long service life.
10.电池欠压指示功能:电量不足时,液晶显示“欠压”,并自动关阀,提醒用户更换电池。
10. Battery under-voltage indication function: when the power is insufficient, LCD displays "under-voltage" and automatically shuts off the valve to remind users to replace the battery.
11.自洁功能:水表定期自动开关阀一次,有效避免结垢、锈死阀门现象。
11. Self-cleaning function: The water meter automatically switches on and off the valve once regularly, effectively avoiding scaling and rusting of the valve.
12.具备预付费功能:能够实现“先购水,后用水”的用水管理新模式。
12. With prepaid function: it can realize the new water management mode of "buy water first, then use water".
本文由IC卡智能水表整理,本文不代表本站观点
This article is organized by IC card intelligent water meter. This article does not represent the viewpoint of this station.
