ACU-THINCUT-OFF BLADES
发表于:2026-6-6 10:57:34|本帖共 4,098 字 2725
       ACU-THIN™CUT-OFF BLADES BUEHLER® ACU-THIN™ Cut-off Blades have been specially developed to improve material sectioning. The key advantages of these blades are: • Cooler cutting action across a wide range of materials • Reduction of kerf loss • Easier sectioning of small, delicate parts • Minimal structural damage to the specimen • Reduced cutting costs
  BUEHLER’s ACU-THIN Cut-off Blades have been formulated for fast sectioning of small, delicatespecimens, as well as large, sturdy specimens. These blades give the user a versatile cuttingoption that proves effective over a variety of speci-men types.
  A key feature of ACU-THIN Cut-off Blades is theirability to reduce kerf loss. Due to the thin designof these blades, surface contact is minimized,resulting in less heat generation and easier cut-ting during the sectioning process.
  An additional benefit of the ACU-THIN Cut-offBlade design is that less pressure is needed forproper sectioning. This requirement for less pres-sure reduces the chances of burning the speci-men or altering its inherent structure. In turn,quality, cost-effective sectioning is achieved witha reduction of sub-surface damage to specimens.
  ACU-THIN Cut-off Blades have been speciallydesigned to cut a multitude of materials of vary-ing hardness levels. There are two blades for eachdiameter size, one for specimens of HRC 45 andabove, and another for specimens with hardnesslevels below HRC 45. When cutting specimensof varying hardness, the user does not have tochange the blades as frequently and can conve-niently cut his specimens with ease.
  ACU-THIN Cut-off Blades offer a new cuttingtechnology that can be utilized for sectioning aspectrum of specimen types. Their efficientdesign makes them ideal for material sectioningin production applications as well as standardlaboratory use.
  PRESSLAM 2.0+德国贺利氏古莎Heraeus Kulzer全自动大尺寸热镶嵌机 Technomat德国贺利氏Heraeus Kulzer压力锅冷镶嵌埋成型机 MASTERLAM 3.0德国贺利氏Heraeus全自动磨抛机 SMARTLAM 2.0德国贺利氏Heraeus手动磨抛机 CUTLAM Micro2德国贺利氏Heraeus精密切割机 COVER LAM德国贺利氏古莎Heraeus Kulzer金相样品保护膜 Technovit 3040德国贺利氏古莎Heraeus Kulzer高精度印模树脂 Bio DIAMANT德国贺利氏古莎Heraeus金刚石抛光磨料金刚石悬浮液 Finishing liquid德国贺利氏古莎Heraeus Kulzerzui终抛光液 Cameo Disk德国贺利氏古莎Heraeus宝石铂金磨盘金刚石磨盘 Technotherm德国贺利氏古莎Heraeus Kulzer热镶嵌树脂 Technovit 4006德国贺利氏古莎Heraeus高度透明冷镶嵌树脂 Technovit 4002德国贺利氏古莎Heraeus硬度的无缝包埋树脂 Heraeus Kulzer德国贺利氏古莎金相润滑切割冷却液 精密德国贺利氏古莎Heraeus Kulzer切割轮片 Technotherm德国贺利氏古莎Heraeus Kulzer镶嵌树脂 CN-德国贺利氏古莎Heraeus Kulzer泰克诺曼TECHNOMAT冷镶嵌压力锅不锈钢高压锅
  g o l a t a C r e b m u N r e t e m a i D s e h c n I e z i S ) m m ( e z i S r o b r A ) m m ( s e h c n I , l a i r e t a M e s U d e d n e m m o c e R l e v e L s s e n d r a H s s e n k c i h T ) m m ( s e h c n I / * d n o B e v i s a r b A 0 1 0 - 0 6 0 4 - 0 15² ) m m 7 2 1 (0 0 5 . ² ) m m 7 . 2 1 ( m m e v o b a d n a 5 4 c R ; l e e t s d r a h , l o o T9 1 0 . 0 ² ) m m 0 8 4 . (l A / R 2O3 0 1 0 - 1 6 0 4 - 0 15² ) m m 7 2 1 (0 0 5 . ² ) m m 7 . 2 1 ( m m w o l e b d n a 5 4 c R ; l e e t s t f o s , d r a h . d e M9 1 0 . 0 ² ) m m 0 8 4 . (l A / R 2O3 0 1 0 - 0 6 1 4 - 0 19² ) m m 9 2 2 (5 2 . 1 ² ) m m 5 7 . 1 3 ( m m e v o b a d n a 5 4 c R ; l e e t s d r a h , l o o T5 2 0 . 0 ² ) m m 5 3 6 . (l A / R 2O3 0 1 0 - 1 6 1 4 - 0 19² ) m m 9 2 2 (5 2 . 1 ² ) m m 5 7 . 1 3 ( m m w o l e b d n a 5 4 c R ; l e e t s t f o s , d r a h . d e M5 2 0 . 0 ² ) m m 5 3 6 . (l A / R 2O3 0 1 0 - 0 6 2 4 - 0 10 1 ² ) m m 0 5 2 (5 2 . 1 ² ) m m 5 7 . 1 3 ( m m e v o b a d n a 5 4 c R ; l e e t s d r a h , l o o T0 3 0 . 0 ² ) m m 2 6 7 . (l A / R R 2O3 0 1 0 - 1 6 2 4 - 0 10 1 ² ) m m 0 5 2 (5 2 . 1 ² ) m m 5 7 . 1 3 ( m m w o l e b d n a 5 4 c R ; l e e t s t f o s , d r a h . d e M0 3 0 . 0 ² ) m m 2 6 7 . (l A / R R 2O3 0 1 0 - 0 6 3 4 - 0 12 1 ² ) m m 0 0 3 (5 2 . 1 ² ) m m 5 7 . 1 3 ( m m e v o b a d n a 5 4 c R ; l e e t s d r a h , l o o T2 3 0 . 0 ² ) m m 3 1 8 . (l A / R 2 O3 0 1 0 - 1 6 3 4 - 0 12 1 ² ) m m 0 0 3 (5 2 . 1 ² ) m m 5 7 . 1 3 ( m m w o l e b d n a 5 4 c R ; l e e t s t f o s , d r a h . d e M2 3 0 . 0 ² ) m m 3 1 8 . (l A / R 2O3
  ACU-THIN™ Abrasive Blades * R = Rubber RR = Resin Rubber ISOCUT® Fluid and ISOCUT® PLUS Fluid are the two recommended cutting solutions for all precision sectioning saws. ISOCUT Fluid is an oil-based coolant which can reduce cutting times significantly on many types of materials. ISOCUT PLUS Fluid was developed for use on high speed, higher load saws like the ISOMET™ 2000. This fluid is water- based and should be used on any saw sectioning samples which partly consist of a water soluble phase. Cutting Fluids Fluid Application Quantity Number ISOCUT® Fluid ISOMET™ Saws 1 qt. (0.95l) 11-1193-032 ISOCUT® Fluid ISOMET™ Saws 1 gal. (3.8l) 11-1193-128 ISOCUT® Plus Fluid ISOMET™ 2000 1 pt. (0.476l) 11-2293-016 Soluble Oil Abrasive Cutters 1 qt. (0.95l) 10-3330-032 Soluble Oil Abrasive Cutters 1 gal. (3.8l) 10-3330-128 Soluble Oil Abrasive Cutters 5 pt. (19l) 10-3330-6407
值得学习
2026-6-13 00:04:10|本帖共 4 字 回复
2026-7-7 08:27:19|本帖共 4 字 回复
很有帮助
2026-8-2 04:02:39|本帖共 4 字 回复
