产品手册 厂家供应开关电源 批发开关电源
发表于:2026-4-22 10:49:27 4223
       厂家供应开关电源 批发开关电源 型号:S-150-5
  低价格、高可靠 Low price and high reliability
  105℃输出电容器 105℃output capacitor
  适用AC输入电源 AC input power suitable for the world
  效率高、工作温度低 High efficiency and low operation temperature
  软启动电流、有效降低AC输入冲击 Soft-start current can reduce the AC input impact efficiency
  有短路保护、过载保护 With short-circuit and overload protection
  体积小、重量轻 Compact size, light weight
  100﹪满负荷烧机测试 100﹪full-load burn-in test
  内装EMI滤波器、纹波极小 Installed with EMI filter, minimum wave
  型号 Mode
  性能 Performance
    S-150-5
    S-150-7.5
  S-150-9
    S-100-12
   S-100-13.5
   S-100-15
    S-100-24
    S-100-27
   S-100-48
  直流输出电压
  DC output voltage
  3V
  5V
  7.5V
  12V
  13.5V
  15V
  24V
  27V
  48V
  输出电压公差
  Output voltage tolerance
  ±2﹪
  ±2﹪
  ±1﹪
  ±1﹪
  ±1﹪
  ±1﹪
  ±1﹪
  ±1﹪
  ±1﹪
  额定输出电流
  Rated output current
  30A
  20A
  16.7A
  12.
  11.
  10A
  6.
  5.6A
  3.2A
  输出电流范围
  Output current range
  0~30A
  0~20A
  0~16.7A
  0~12.
  0~11.
  0~10A
  0~6.
  0~5.6A
  0~3.2A
  纹波及噪音
  Ripple and noise
  150mVp-p
  150mVp-p
  120mVp-p
  100mVp-p
  100mVp-p
  100mVp-p
  100mVp-p
  100mVp-p
  75mVp-p
  进线稳定度
  Inlet stability
  ±0.5﹪
  ±0.5﹪
  ±0.3﹪
  ±0.3﹪
  ±0.3﹪
  ±0.3﹪
  ±0.2﹪
  ±0.2﹪
  ±0.2﹪
  负载稳定度
  Load stability
  ±0.5﹪
  ±1﹪
  ±0.5﹪
  ±0.3﹪
  ±0.3﹪
  ±0.3﹪
  ±0.2﹪
  ±0.2﹪
  ±0.2﹪
  直流输出功率
  DC output power
  150W
  150W
  150W
  150.3W
  150W
  150.2W
  156W
  151.2W
  153.6W
  效率
  Efficiency
  80﹪
  80﹪
  80﹪
  82﹪
  83﹪
  84﹪
  85﹪
  86﹪
  87﹪
  直流电压可调范围
  Adjustable range for DC voltage
  4.5-5.5V
  6-8.35V
  8-10.45V
  10.6-13.2V
  12-15V
  13.5-16.5V
  21-28V
  24-30V
  43.-53V
  输入电压范围
  AC input voltage range
  85~132VAC/170~264VAC由开关选择47~63Hz; 240~370VDC
  85~132VAC/170~264VAC selected by switch 47~63Hz; 240~370VDC
  输入电流
  Input current
  3.2A/115V 1.6A/230V
  冲击电流
  AC dash current
  冷启动电流30A/115V 60A/230V
  Cold-start current 30A/115V60A/230V
  漏电流
  Leakage current
  <3.5mA/240VAC
  过载保护
  Overload protection
  105﹪~150﹪类型:切断输出 复位:自动恢复
  105﹪~150﹪ Type: pulsing hiccup shutdown reset: auto recovery
  过电压保护
  Over-voltage protection
  115%--135%
  高温保护
  High-temperature protection
  温度系数
  Temperature coefficient
  ±0.03﹪/℃(0~50℃)
  启动、上升、保持时间
  Startup .rise .retention time
  100ms 50ms 20ms
  抗震性
  Vibration
  10~500Hz,2G10min/1周期,时长60分钟,各轴
  10~500Hz,2G10min/1 cycle , Period for 60 min , Each axes
  耐压性
  With standard voltage
  输入输出间:1.5KvAC输入与外壳: 1.5KvAC输出外壳: 0.5KvAC
  Input and output internal :1.5KvAC input and enclosure : 1.5KvAC output and enclosure: 0.5KvAC
  隔离电阻
  Isolation resistance
  输入输出间: 输入与外壳,输出与外壳:500VDC/100MΩ
  Input and output internal: input and enclosure. Output and enclosure: 500VDC/100MΩ
  工作温度、湿度
  Working temperature and humidity
  -10℃~+60℃(参考输出特性图),20﹪~90﹪RH
  -10℃~+60℃(Refer to output diagram cech,20﹪~90﹪RH
  存储温度、湿度
  Store temperature and humidity
  -20℃~+85℃, 10%~95%RH
  外型尺寸
  Overall dimension
  199×98×38mm
  重量
  Weight
  0.7kgs
  安全标准
  Safety standards
  UL1012 TUV按6050(IEC,UL1950)认证
  UL 1012 TUV EN6050(IEC,UL1950) Approved
  EMC标准
  EMC standards
  CISPR22(按55022),IEC801-2,3,4IEC555 -2认证
  CISPR22(EN55022),IEC801-2,3,4IEC555 -2 Verification
  备注: 1.以上参数测试条件为:230VAC输入,额定负载,25℃70%Rh,温度。
   2.容差: 包括设定容差,线路稳定度,负载稳定度
   3.纹波测试:20MHz用“A12”双绞线,中断用0.1uF&47uF电容器短路。
   4.进线电压稳定度测试:满负载时进线zui低电压到zui高电压。
   5.负载稳定度测试:负载从0%到99%
  Note : 1. The testing condition for the parameter above is : 230VAC input ,rated load,25℃70%Rh. Temperature.
   2. Error, include the setting error, line stability and load stability .
   3. Wave test: adopt “A12”double wire for 20MHz, and 0.1UF & 47UF capacitor short-circuit for interrupting.
   4. Inlet voltage stability test: when is over load, the lowest voltage of inlet is up to the highest voltage.
   5. Load stability test: The load is from 0% to99%
这个经验值得收藏
2026-6-5 01:30:41 回复
