骨形成蛋白1(BMP1)检测试剂盒
发表于:2026-4-3 09:35:15|本帖共 3,965 字 2511
       骨形成蛋白1(BMP1)检测试剂盒
  适用生物 Homo sapiens (Human,人) 骨形成蛋白1(BMP1)检测试剂盒检测范围 15.63-1000pg/mL 灵敏度 5.8pg/mL 样本类型 Serum, plasma, tissue homogenates and other biological fluids. 实验时长 4.5h 实验方法 双抗夹心法 骨形成蛋白1(BMP1)检测试剂盒规格 96T ELISA Kit for Bone Morphogenetic Protein 1 (BMP1) FOR IN VITRO AND RESEARCH USE ONLY, NOT FOR USE IN CLINICAL DIAGNOSTIC PROCEDURES!
  Organism species Homo sapiens (Human) 骨形成蛋白1(BMP1)检测试剂盒Sample type Serum, plasma, tissue homogenates and other biological fluids. Format 96-well strip plate Assay length 4.5 hours Detection range 15.63-1000pg/mL The standard curve concentrations used for the ELISA’s were 1000pg/mL, 500pg/mL, 250pg/mL, 125pg/mL, 62.5pg/mL, 31.25pg/mL, 15.63pg/mL Sensitivity The minimum detectable dose of this kit is typically less than 5.8pg/mL.
  Specificity This assay has high sensitivity and excellent specificity for detection of Bone Morphogenetic Protein 1 (BMP1). No significant cross-reactivity or interference between Bone Morphogenetic Protein 1 (BMP1) and analogues was observed. Recovery Matrices listed below were spiked with certain level of recombinant Bone Morphogenetic Protein 1 (BMP1) and the recovery rates were calculated by comparing the measured value to the expected amount of Bone Morphogenetic Protein 1 (BMP1) in samples.
  Matrix Recovery range (%) Average(%) serum(n=5) 88-96 92 EDTA plasma(n=5) 78-90 85 heparin plasma(n=5) 82-90 86
  骨形成蛋白1(BMP1)检测试剂盒Precision Intra-assay Precision (Precision within an assay): 3 samples with low, middle and high level Bone Morphogenetic Protein 1 (BMP1) were tested 20 times on one plate, respectively. Inter-assay Precision (Precision between assays): 3 samples with low, middle and high level Bone Morphogenetic Protein 1 (BMP1) were tested on 3 different plates, 8 replicates in each plate. CV(%) = SD/meanX100 Intra-Assay: CV<10% Inter-Assay: CV<12% Linearity The linearity of the kit was assayed by testing samples spiked with appropriate concentration of Bone Morphogenetic Protein 1 (BMP1) and their serial dilutions. The results were demonstrated by the percentage of calculated concentration to the expected.
  Sample 1:2 1:4 1:8 1:16 serum(n=5) 81-102% 97-105% 95-102% 93-101% EDTA plasma(n=5) 78-92% 78-101% 94-103% 79-96% heparin plasma(n=5) 79-97% 99-105% 91-99% 82-101%
  Stability The stability of kit is determined by the loss rate of activity. The loss rate of this kit is less than 5% within the expiration date under appropriate storage condition. To minimize extra influence on the performance, operation procedures and lab conditions, especially room temperature, air humidity, incubator temperature should be strictly controlled. It is also strongly suggested that the whole assay is performed by the same operator from the beginning to the end. Reagents and materials provided
  Reagents Quantity Reagents Quantity Pre-coated, ready to use 96-well strip plate 1 Plate sealer for 96 wells 4 Standard 2 Standard Diluent 1×20mL Detection Reagent A 1×120μL Assay Diluent A 1×12mL Detection Reagent B 1×120μL Assay Diluent B 1×12mL TMB Substrate 1×9mL Stop Solution 1×6mL Wash Buffer (30 × concentrate) 1×20mL Instruction manual 1
  Assay procedure summary 1. Prepare all reagents, samples and standards; 2. Add 100μL standard or sample to each well. Incubate 2 hours at 37oC; 3. Aspirate and add 100μL prepared Detection Reagent A. Incubate 1 hour at 37oC; 4. Aspirate and wash 3 times; 5. Add 100μL prepared Detection Reagent B. Incubate 30 minutes at 37oC; 6. Aspirate and wash 5 times; 7. Add 90μL Substrate Solution. Incubate 15-25 minutes at 37oC; 8. Add 50μL Stop Solution. Read at 450nm immediay. 骨形成蛋白1(BMP1)检测试剂盒Test principle The test principle applied in this kit is Sandwich enzyme immunoassay. The microtiter plate provided in this kit has been pre-coated with an antibody specific to Bone Morphogenetic Protein 1 (BMP1). Standards or samples are then added to the appropriate microtiter plate wells with a biotin-conjugated antibody specific to Bone Morphogenetic Protein 1 (BMP1). Next, Avidin conjugated to Horseradish Peroxidase (HRP) is added to each microplate well and incubated. After TMB substrate solution is added, only those wells that contain Bone Morphogenetic Protein 1 (BMP1), biotin-conjugated antibody and enzyme-conjugated Avidin will exhibit a change in color. The enzyme-substrate reaction is terminated by the addition of sulphuric acid solution and the color change is measured spectrophotometrically at a wavelength of 450nm &plusmn; 10nm. The concentration of Bone Morphogenetic Protein 1 (BMP1) in the samples is then determined by comparing the O.D. of the samples to the standard curve.
评论列表(6)
2026-4-9 07:21:05|本帖共 4 字 回复
很到位
2026-4-14 18:06:40|本帖共 3 字 回复
不错
2026-5-8 15:35:32|本帖共 2 字 回复
2026-5-23 15:09:35|本帖共 4 字 回复
2026-6-15 00:35:18|本帖共 4 字 回复
讲得透彻
2026-8-1 22:35:41|本帖共 4 字 回复
