AXIS安讯士M3058-PLVE Network Camera 12 MP dome with 360° panoramic view for all light conditions Flat, vandal-resistant indoor/outdoor design Complete 360° overview with outstanding sharpness Forensic WDR, Lightfinder and OptimizedIR Axis Zipstream technology 12 MP sensor
Need great performance in any light – or no light at all? AXIS M3058-PLVE Network Camera delivers a complete 180° or 360° overview, indoors or out, around the clock. Plus it features Axis Zipstream technology for reduced bandwidth and storage without sacrificing the forensic detail you need. AXIS M3058-PLVE is perfect for stores, hotels, offices, banks, schools and hospitals. Or anywhere you need a complete overview 24/7.
Use AXIS M3058-PLVE indoors or outdoors for a wide variety of purposes anytime of the day or night. Thanks to OptimizedIR and a long list of features that spell, flexible. With the optional black skin cover you can repaint AXIS M3058-PLVE – easily – and it blends in anywhere. And count on the IK10 rating for protection against vandalism and the IP66 rating to keep the camera safe from dust and powerful blasts of water. Which means exposure to the elements is no problem.
You can stream the complete 360° overview. That way you can be sure that you record everything with no blind spots. And the video management software can use that one video stream to produce any dewarped views you’d like. Or you can choose to stream dewarped views such as panorama, quad, corner and corridor views directly from the camera. And you can digitally pan, tilt and zoom in on areas of interest in up to four areas simultaneously.
AXIS M3058-PLVE is made to deliver sharp images, to the edges, in any light – or no light: OptimizedIR means this camera can “see” in the dark – so there’s no need to turn on the lights at night. It’s equipped with Forensic WDR for visibility when there are both dark and light areas in the same scene. And AXIS M3058-PLVE has Lightfinder technology for life-like colors when the lighting is low.
AXIS M3058-PLVE features a stereographic lens. This lens achieves a higher resolution around the outer portion of the view than in the center, meaning that interesting objects located at a distance in the camera’s peripheral view can be captured more clearly. This is particularly useful when the camera is installed facing downwards.
AXIS M3058-PLVE includes Axis Zipstream technology, which analyses the video stream in real time to identify areas of interest. Important details in these areas are preserved in full video quality, while other areas are more compressed, reducing storage and bandwidth by up to 50%. The result is high-quality video and significant savings.
Installing and setting up AXIS M3058-PLVE is fast, simple and cost effective. AXIS M3058-PLVE is factory focused and ready to use, right out of the box.
AXIS M3058-PLVE also has I/O ports, so you can connect a sensor or detector to the camera’s digital input to trigger alarms or actions. Output ports can be connected to control devices or relays, for instance, to open/close doors or turn on/off lights upon alarm.
销售电话(微信同号):
